Chassis Ground
0 Members and 1 Guest are viewing this topic. Read 1352 times.
ecir38
Chassis Ground
« on: 17 Oct 2007, 07:01 pm »
I am finally finished a Piccolo, Cornet2, and Clarinet. I will be cranking all them up at the same time.
What will be the best way to ground the chassis? I am thinking that I should use the ground from the turntable to the Piccolo or Cornet2 and everything else would be grounded through the RCA's.
tubesforever
Re: Chassis Ground
« Reply #1 on: 17 Oct 2007, 07:30 pm »
My recommendation is to ground the tone arm and turntable to the Piccolo separately.  Sometimes you have to ground the table, other times you do not.  Sometimes you get a hum grounding the table but get static discharges if you do not ground the arm.  This gives you maximum flexibility.
Ground the Piccolo to the CornetII only if you hear a hum.  As you mentioned, the remainder of the equipment will ground through the RCAs.
BTW, when you can, please send me the order numbers for the screw down green connectors you use for resistance loading.  I want to run these on a CineMag SUT I am building now.  These are just way too juicy.
