Auditioning Sub Tomorrow - Need Music Suggestions
0 Members and 1 Guest are viewing this topic. Read 2090 times.
Captain Humble
« on: 6 Sep 2003, 02:06 pm »
Any suggestions regarding good sub demo tunes would be appreciated.  I don't have any RAP stuff and never will.
U4EA offered Dave Young's 2x2 sessions in an old post.
Jeff
cyounkman
« Reply #1 on: 6 Sep 2003, 02:32 pm »
Try anything by Bjork: Post, Vespertine, Debut. All have deep synth bass lines.
A good recording of the Mahler 6 will test reproduction of bass drums, etc.
Saint-Saens Organ Symphony can be fun as well.
JohnR
« Reply #2 on: 6 Sep 2003, 02:57 pm »
Um... what's the point of auditioning using music you don't listen to?
KevinW
« Reply #3 on: 6 Sep 2003, 03:45 pm »
One thing to keep in mind about subwoofers is the room resonance modes often dominate in the low bass regions.  This is because the wavelength of a bass wave (20Hz = 56 feet) is about the same size as the typical listening room.  So big standing waves can be excited in the room, which resonate and completely dominate an otherwise perfectly flat response in the sub.
Of course, since every room has different dimensions, every subwoofer has different a different sound simply by moving it into a different room.
The ways to handle this are to have bass traps, multiple subs (in the horizontal and vertical dimensions), or use a spectrum analyzer and graphic equalizer to electronically kill the bass peaks.
Having said all that, I personally use a single sub, without distortion-causing equalization, and am quite happy.  Home theater is a little boomy, but most music bass notes are high enough that room resonances are not excited in my room.  I use (and sell) sealed subs because they are much more musical compared to ported designs.
If you want my advice in musical choices for testing subwoofers... Bob Marley is great.  On a good system, the bass is very tight, musical, and tuneful.  If there's any problems with the subwoofer, it will sound boomy as all hell.  The remastered versions of Catch A Fire or Exodus are primo.
Pez
« Reply #4 on: 6 Sep 2003, 05:51 pm »
Quote from: JohnR
 :rotflmao:
John has a point. Just bring what you know. I always thought it funny when people ask "what should I bring to listen to?" How could you possibly know what to listen to unless you are intimately familiar with the material.
« Reply #5 on: 6 Sep 2003, 07:25 pm »
Pez,
"Chose your words"?  Dumbass.
« Reply #6 on: 6 Sep 2003, 07:27 pm »
Among the better music to demo subs with is Patricia Barber and Dianna Krall, both have acoustic bass being played up and down the scale, sometimes very quickly.  If a sub has bloat/overhang, you will hear it pretty quickly with this type of music.
Tonto Yoder
« Reply #7 on: 7 Sep 2003, 10:58 pm »
Quote from: Tyson
I like Barber's "Companion"--
this isn't the track I'd use but might give an idea of why Barber would be appropriate-
http://www.patriciabarber.com/realmedia/isntjazz.ram
The bass isn't  like Yello's electronic spectaculars, but if a system replicates this bass well, I think it'll be satisfying in the long run.
