Thinking about SS Monoblocks next...any ideas?
0 Members and 1 Guest are viewing this topic. Read 4500 times.
Larkston Zinaspic
« on: 8 Oct 2007, 02:10 am »
In particular I'm considering the Mono Extremes from Odyssey Audio and the D-200 monoblocks from Channel Islands Audio. Since I see that there are owners of those particular amps here I was wondering if I could get some input to aid in making that decision.
I have to admit, I really like the compact size of the D 200s, but I recall discussing digital amps with Klaus, and not to put words in his mouth, it seemed as though he had a pretty negative view of them.
Nevertheless, all insights are well-appreciated.
Marbles
Re: Thinking about SS Monoblocks next...any ideas?
« Reply #1 on: 8 Oct 2007, 02:28 am »
With regard to Klaus, I don't think he ever could get (design or find to sell) one that he was happy with.  That he felt passed on the MUSIC and wasn't clinical.  I do know he tried for a long time to get one modified to his satisfaction and he was close, but he just never got one that he was happy to sell.
With regard to Dusty's D200's.  I have no idea how they sound, but Dusty is great to deal with.
PaulFolbrecht
« Reply #2 on: 8 Oct 2007, 02:38 am »
The CI amps are smooth and mellow and do not have the icy steelness of, say, NuForce.  But they do not have the tone of Tripath either to my ear.  Do you need 200W?  Have you considered the RWA 70s if not?
lazydays
« Reply #3 on: 8 Oct 2007, 07:56 pm »
I've had a pair of Mono SE's for about 15 months, and they never cease to amaze me. Extremely fast, great imaging and presense. Built like an M-1 tank. The only thing I've heard that comes close is the big monos from Accuphase. The ones from Krell won't. I suspect that these amps will be the last I ever buy.
gary
Larkston Zinaspic
« Reply #4 on: 19 Oct 2007, 02:56 am »
Those new RWA monos look very nice. My speakers are rated at 4 ohms and 91db...would I be skating on thin ice there?
  • Speakers....What Speakers ?
« Reply #5 on: 19 Oct 2007, 03:32 am »
You'll have no problem.....you can even check with Vinnie.... :thumb:
martinr
« Reply #6 on: 19 Oct 2007, 04:06 am »
gary
Ditto on the Mono SE's- At RMAF Klaus said he has a few new "upgrades" he's introducing as well -
« Reply #7 on: 19 Oct 2007, 09:41 am »
Amps should be sized to provide a commanding grip on speakers.  This would translate into reaching 105 - 110 dB in your room (assuming you don't exceed the speaker's rating).  105 dB is peak for classical music (jazz would be less).  110 dB is average loudness at rock concerts.  I recommend you play with a spl meter to learn how really loud these levels are.  (Most audiophiles I've hung with average closer to 80 dB for critical listening.)
With your rather efficient speakers, that equates to 14 - 19 dB of gain at 4 ohms, or 11 - 16 dB of gain at 8 ohms (where most amps are rated) at the specified 1 meter distance using a single speaker.  That translates into 13 - 40 watts at 8 ohms.
In general with two channels playing a 12 ft x 20 ft room, the room reflection (gain) and the limited distance you can sit away from the speakers the spl you'd measure corresponds roughly to the rated speaker efficiency.  Smaller rooms would have a net gain, larger ones would have a net loss and so need more power.  Heavily dampened rooms would see more of a loss.
Additional power is useful as it avoids clipping the amp, which is the easiest way to destroy speakers but, unless you want to break leases and ruin your ears, the chance of running your system that loud is fairly remote.  This is more of a concern for users of tiny digital amps with average or low efficiency speakers.
I'd also be concerned with the 4 ohm speaker rating.  Is that an average or minimum rating?  Amps typically become unstable under low impedance loadings, however digital amps seem to thrive on low impedance loads.
Not suprisingly, digital versus tube versus solid state opinions vary primarily by what the vendor sells or the owner is currently using.  Listen for yourself.
Also look into your source output sensitivity, your pre-amp input/output sensitivity, and the rated gain from your pre-amp when shopping for a power amp.  It's a common problem to have way more signal coming into the amp than necessary (regardless of the amp's power rating).  The result is limited usable range of your volume control.  For instance I have a CDP with a typical 2.0 volt output, but the monoblocks have a rated input sensitivity (to provide full power) at 0.6 volt.  The result is even with a passive (no gain) pre-amp I reach maximum volume at 10:00 on the volume control, so the volume can be somewhat hard to control.  Having a pre-amp with gain would only make the situation worse.
Big Red Machine
« Reply #8 on: 19 Oct 2007, 10:03 am »
Just ordered 2 Belles 150A Ref amps to run in mono.  I'll know soon if I chose wisely.
carusoracer
« Reply #9 on: 19 Oct 2007, 01:39 pm »
Very informing answer! In my situation with a 12x20 room with vaulted ceiling and 85db/ 8 ohm
 speakers how many SS watts would be needed vs tube watts? Listening ave level 80-90db.
carusoracer
« Reply #10 on: 19 Oct 2007, 01:40 pm »
Pete, sounds like fun. Interested in hearing your opinion once they are dialed in your new room setup.
Have you tried the DNA 500 in the Sanctum?
mcullinan
« Reply #11 on: 19 Oct 2007, 02:18 pm »
I would just like to defend my shining amps in armor. The Nuforce do not have an icy steeliness to them imho! Maybe you hooked them up backwards or upside down... but they have a natural presentation, in between SS and Tube amps in sound.
Mike
« Reply #12 on: 19 Oct 2007, 04:15 pm »
carusoracer,
The numbers I stated are just to get you in the ballpark.  A vaulted ceiling might cost a dB or two from the rated efficiency.  Keep in mind that one dB is the smallest differential volume you can hear and 10 dB sounds twice as loud.
Here is a chart to equate watts to db of gain:
0.01 watts = -100 dB of gain
0.1 watts  = - 10 dB of gain
1 watt     =    0 dB of gain
10 watts  =   10 dB of gain
20 watts  =   13 dB of gain
40 watts  =   16 dB of gain
50 watts  =    17 dB of gain
80 watts  =    19 dB of gain
100 watts =    20 dB of gain
200 watts =    23 dB of gain
500 watts =    27 dB of gain
Sound pressure level peaks can amount to 10 dB (rock) to 30 dB (classical) and its the peaks that put demands on the amps and speakers, so I hesitate to work with average spls.  Your speakers are rather inefficient, so to reach 105 - 110 dB peaks you'd need 130 - 500 watts in your room.
Note that extended exposure to 85 dB or more will lead to permanent hearing loss.
I see solid state versus tube watts debate more of a question of clipping and damping factor.  Tube amps overload more gently than solid state so its safer to overload tube amps.  OTOH many tube amps exhibit very poor damping, which leads to bloated (exagerated, loose) bass.  This coloration can "help" bass weak speakers, but speakers with full bass will sound heavy and mushy.
carusoracer
« Reply #13 on: 19 Oct 2007, 04:24 pm »
Thanks for the breakdown :thumb:
Yes, the Salk HT3's are inefficient that is why I'm trying to get some statistical data. I believe that the Mono Bloc Tube Amps and SS/Hybrid Amps seem to need at least 150 to drive them.
I just threw out the 85db number as my peak, better to aim higher than low. Thanks for the concern.
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
« Reply #14 on: 19 Oct 2007, 05:12 pm »
JLM,
I am new to looking at sound from the dB perspective... thanks for that info, it was very informative.  If I could ask you to delve a bit further... could you comment on the possibility of compression? From an article I read, compression would deduct significant amount of the calculated response in the real world.
Any thoughts on that subject you would care to share?  If it is significant, when is it most likely to be found?
-Tony
sleepysurf
  • Member of the Suncoast Audiophile Society
    • Suncoast Audiophile Society
« Reply #15 on: 19 Oct 2007, 06:56 pm »
Of note, David Belles unveiled his new MB-200 monoblocks at RMAF.  They were paired with his new SS Pre, driving Usher Tiny Dancers and alternatively, a small floor-stander (? brand).  The new Pre/Monos combo sounded real sweet, but price points are a step up from CIA or Odyssey.
Bob Reynolds
« Reply #16 on: 19 Oct 2007, 09:54 pm »
Isn't there a fundamental limitation to running stereo amps in mono relative to the load that they can drive?
Doesn't the stereo 4 ohm spec become the mono 8 ohm spec?
ctviggen
« Reply #17 on: 20 Oct 2007, 12:14 am »
Mike
I've only used the Nuforce for my center channel speaker.  In terms of what I thought sounded best, I like my current tube-based amp.  After that, I liked biamping the center channel with two channels of a Bryston 9B (solid state).  After that, I'd place the Nuforce.  (And perhaps a single channel of the Bryston, which couldn't drive my RM30C.)  The Nuforce was too clinical sounding for me and tended to amplify stuff I didn't want to hear.  It also seemed cold.  That's on a center channel; perhaps they're better as stereo amps (in fact, I'm selling my Nuforce, as soon as I can get around to doing so).
PaulFolbrecht
« Reply #18 on: 20 Oct 2007, 12:35 am »
Your experience echoes mine and many others'.
mcullinan
« Reply #19 on: 20 Oct 2007, 12:52 am »
No.. They are far from icy... maybe you can attribute this sound to the rest of your components.. After all everything is about synergy.
Mike
« Last Edit: 22 Oct 2007, 02:16 pm by mcullinan »
