DigiAmp Questions
Czilla9000
DigiAmp Questions
« on: 5 Sep 2003, 10:32 pm »
Hi.....
About the ZAP Pulse and the PSU unit listed on the DIY Cable Website.....can the PSU (the Virtual Pole one) be used to power a LClock (and maybe a DAC) as well? Thank you!
Kevin P
    • http://www.diycable.com
DigiAmp Questions
« Reply #1 on: 6 Sep 2003, 02:31 pm »
The ZAPPulse PSU is strictly designed for the ZAPPulse amplifier.
For the LClock we have a dedicated power supply designed that you can find here:
http://www.diycable.com/main/product_info.php?cPath=32_87&products_id=198
Most DACs only need 12V and/or 5V DC power sources.  The manufactures of a given DAC will have datasheets showing power requirements.  You can design a simple power supply or I'm sure that there are schematics online somewhere for audiophile grade 12V & 5V power supplies.
Best of luck.
