I was also wondering where you bought the display plastic from?I can get some smoked acrylic from mcmaster.
Randy & Tom,I just used the original display plastic from the SB2. Nothing fancy. When I built the Burson/Preamp I did use some smoked acrylic that I had on hand. It came from an old CD tower front cover. In this case the front panel is .1875 thick (3/16" inch). I machined the recess in the back .100" deep, leaving .087 as the lip. Obviously the plastic isn't flush. And as Tom mentioned, the machined AL is visible since the panel is pre-anodized. I just use a black marker on the lip where it's machined. Not a perfect match but close enough given the size. Plus, since the machine are is at a 90* angle to the face plate, the color difference is much less noticeable. If you did want to flush the plastic it would certainly be more work. Get something like .250" thick smoked acrylic and machine the acrylic to fit inside the recess with a portion sitting inside the recess to make it flush with the front panel. For me this wasn't worth the effort but could be done. If one were to make the front panel from hardwood it wouldn't be nearly as difficult since to make a nice opening you would need a router with a guide bushing and a template. You could use the template and guide bushing setup to cut the acrylic as well though I'm not sure how well acrylic reacts to a 20,000 rpm cutter. It may be hard to keep it from melting. When I cut the opening I measured the original lens and then subtracted .100 from each side of the width and .125 from the length for the opening size. The recess is cut to the lens size although I shortened it very slightly. I believe The final dimensions were 1.000" for the opening width and 1.200" for the recess width. I think (not at home, no drawing here) that the length was 7.5" but it might be a little shorter. The reason I did this was there are four small circular molding marks in the lens corners and I didn't want them to show. The SB2 case corner radius normally hides these but since I used a .250" diameter end mill the .125" radius wouldn't cover it. As for securing it, just a couple small (really small) drops of hot glue in the recess. Hope this helps. Mike
Randy,So, you can have your choice. I looked on the eStreetPlastics site and they offer 3/16" as well. They have 1/4" too, so you might be able to have FPE machine some 1/4" to match the thickness of the panel so it would be flush and still leave a lip to mount it with. Hmm, thinking about it this is likely what I'll do when I build the next one. As for Peter's stuff, yeah it's in a different league altogether. Mike
Randy,I'm probably going to go big on the case, maybe 16x16x4. Might as well save some room for other goodies. Are you going to have FPE punch the rear panel for AC, fuse, various I/O's too? I was thinking of re-using the XLR from the PS as a power output on the re-case so I could connect another SB3 if necessary. Also, connect the SB2 analog direct out to a set of RCA's as well as to the inputs of the Burson Buffer which would have it's own set of outputs. Then, maybe have a 75ohm BNC for the digital output. Just trying to cover all the bases Tom
