6B-SST Heat
0 Members and 1 Guest are viewing this topic. Read 1153 times.
gingellr
6B-SST Heat
« on: 5 Oct 2007, 02:44 pm »
Hi,
I have just taken delivery of my new 6B-SST, what a great sound!
I have a quick question, when i demoed the 4B-sst the side heatsinks only got luke warm.
The 6B heatsinks are running alot hotter, can someone confirm this is normal?
Richard
  • The Demo is Everything!
    • http://www.bryston.com
Re: 6B-SST Heat
« Reply #1 on: 5 Oct 2007, 02:49 pm »
Hi,
Richard
james
Hi Richard,
As long as the heatsink does not get too hot to touch then your OK. The 6B will run hotter than the 4B because you have 3 full channels of 300 watts in one chassis. Also each amplifier is bias independently in final checkout so there will be temperature differences from amp to amp.
james
