Vista audio i84 usage as preamp?
george_k
« on: 5 Oct 2007, 01:03 pm »
I currently have a pair of B&W 703's and although the quoted manufacturer efficiency is 90dB an a reviewer noted otherwise:
"I would judge this speaker to be moderately difficult to drive. For that reason, I would conservatively rate its nominal impedance at 4ohms. The 703's sensitivity measured about 88dB/2.83V/m."
I use the speakers for both music and 2 ch HT. I like the sound of tubes but I need the grunt of a high power transistor amp to properly drive these speakers. Would it be possible/advisable to use the i84 as a preamp (can it be done)?
If not, does vista audio plan on producing a preamp in the near future?
Audiovista
Re: Vista audio i84 usage as preamp?
« Reply #1 on: 6 Oct 2007, 01:29 am »
Hi George,
Thanks for "visitng"  :thumb:
The model i84 does not have preamp outputs so you would not be able to use it with an SS amplifier without making some cumbersome mods (such as adding a voltage divider at the output to reduce voltage to an acceptable level).
Right now Vista-Audio has only some prototypes of a tube preamp (as we currently sell only integrated amps, preamp is not on top of our priorities). But we also represent a Hong Kong company with an extremely fast (10Hz - 100kHz) remote controlled tube preamp. The preamp is priced at $960. Currently there are none in stock, but it can be preordered for $820.00. Lead time is currently ~8 weeks.
Thanks again,
Boris
RawB8figure
« Reply #2 on: 17 Oct 2007, 01:57 am »
how much for a set of the 50W monoblocks
Audiovista
« Reply #3 on: 18 Oct 2007, 01:30 am »
I guess you're asking about Radii monoblocks with 805 tubes....
Radii monoblocks are $2,700 (pair). However, I have none in stock, so there is a 20% discount for preorders ($2,160). I have one demo pair, will be available in a week for $1,700. Shipping is extra (two large boxes, 60lbs each).
Boris
SET Man
« Reply #4 on: 18 Oct 2007, 01:47 am »
Hey!
  Got this pic off you site Boris. :D Man!  :drool:
   I get turn on when I see high power SET amps  :lol:
Take care,
Buddy :thumb:
Audiovista
« Reply #5 on: 19 Oct 2007, 12:21 am »
Thanks Buddy, took the picture myself.... 8)
