Walnut Songtowers
0 Members and 1 Guest are viewing this topic. Read 2685 times.
jsalk
Walnut Songtowers
« on: 30 Sep 2007, 12:36 pm »
Walnut is one of the "standard" SongTower finishes.
Here is the first pair in walnut...
And a close-up...
- Jim
carusoracer
Re: Walnut Songtowers
« Reply #1 on: 30 Sep 2007, 02:52 pm »
Very Cool   8)
Toka
« Reply #2 on: 30 Sep 2007, 03:30 pm »
Walnut is one of my favorites. Classy, always seems to work in any situation.  8)
Quick question, and perhaps a bit off-topic, but I see in the pic that the tweeters are oriented on the "inside", as opposed to the "outside"...for some reason I assumed it would be the other way around...is one way intended, or does it just depend on the room?
DMurphy
    • SalkSound
« Reply #3 on: 30 Sep 2007, 04:56 pm »
I've always heard the pair should be oriented as Jim has shown, but I've never seen an explanation.  It may depend on the tweeter and crossover frequency--I assume you would want the side with the smoothest off-axis response to be next to each other. I think that's the case with the ST, but I'll have to check again.  I also have a feeling it doesn't make a lot of doo-dah difference.  But then I never do.  dah.
