8.5 v2 shut down: hump da bump!?
0 Members and 1 Guest are viewing this topic. Read 1798 times.
montag451
« on: 28 Sep 2007, 10:20 pm »
when i switch off the units (i do switch off the p8 via remote, first), i can hear, after few sec, a good bump from one amp and, after 2-3 sec, a noisy crack (or a whiplash..) from the other one. i'm concerned about two things:
  • will  my maggies suffer this bump-crack?
  • assumed strict tolerances exist in this  hi tech products, how can they behave so unevenly when switched off?
rustydoglim
    • www.nuprimeaudio.com
Re: 8.5 v2 shut down: hump da bump!?
« Reply #1 on: 29 Sep 2007, 09:33 pm »
The correct sequence is to power off the amp before the preamp (the sequence is reversed for powering on).
These are high tech designs, but the amp is purely analog! When you have hundres of discrete analog devices on a board (each one of them have slight variation), there will be slight differences in behavior.  For example, at 1KHz, the THD measurement is slightly different for every amp but as long as it falls within a range of 0.01 to 0.04%, it passes production test. Even the same amp would measure slightly different every time.
When the power gets cut off, as the capacitors decharges, we can not guarrantee every amp behave exactly the same. If you turn them off in the right sequence, there should be little or no turn off sound. But some small amount of psst, tuuup is normal.  It will not harm your speaker.
montag451
« Reply #2 on: 30 Sep 2007, 03:30 pm »
thanks jason.
at the moment i'm shutting 'em off after the P8. i'll try the reverse order. i'll tell you if something changes.
montag451
« Reply #3 on: 3 Oct 2007, 08:26 pm »
tryed inverse shut down order: no harmful hump da bump at all. everything's ok, now. :thumb:
thanks jason for your appreciated advice!! :D
