Cardas XLR Caps
0 Members and 1 Guest are viewing this topic. Read 1311 times.
Tbadder1
Cardas XLR Caps
« on: 4 Sep 2003, 12:46 pm »
Okay, I bought some of these used a year or two ago and put them away for some reason.  Now, I'd like to throw them on the amp, but I hear that I must do this correctly or I'll short the pre-amp section out.  Does anyone know off hand which of the three holes the stem is inserted to for proper functioning.  Believe it or not the Cardas website does not have this information.  Thanks for any help guys!
Dan
PhilNYC
Cardas XLR Caps
« Reply #1 on: 4 Sep 2003, 05:26 pm »
There's actually only one way for it to fit...you'll notice on the sleeve of the cap, there's a slit...this prevents you from putting the cap on the wrong way.
Phil
Tbadder1
DOH!!!!!!!!!
« Reply #2 on: 4 Sep 2003, 07:59 pm »
Dan
