Monarchy NM24
0 Members and 1 Guest are viewing this topic. Read 1707 times.
Housteau
Monarchy NM24
« on: 23 Sep 2007, 01:42 am »
I just received my unit yesterday and have had a few hours to enjoy it and get a few first impressions.  It is second hand, a few months old, and so the stock tubes (two for the DAC and two for the preamp section) have had some time to burn in.  I do plan on experimenting with other tubes at a later date, but first I want to enjoy what I have here now and allow the tubes to burn in a bit more.
I have gotten into the habit of doing a lot of critical listening lately comparing different front ends and preamp sections, and to be honest, I don't enjoy doing that sort of thing most of the time.  Critical listening takes away a lot of the enjoyment I normally get from just listening to the music.  So, with this new front end I hope to get back to what I enjoy the most.
I had use of a new Benchmark DAC1 for a few days and did appreciate what it did in my system.  I was using my older Musical Fidelity X-Ray as the transport.  I especially noticed the tight focus and detail it brought to the presentation.  I was also using it as a replacement for my older Audio Research preamp.  At the same time I had use of Placette Audio's passive volume control.  In using it with my Jolida minus the DAC1, I noticed a similar tightening and focus within the soundstage.  Also, it was as if several veils were lifted out of the way between me and the performance.  This told me that there was something wrong with my AR preamp and that regardless of which front end I would eventually go with, this preamp of mine is a weak link in my system chain.  So, when searching for something new, I was hoping to find a nice all-in-one component that would cure what was holding my system back.  I actually liked the Benchmark, but I need at least one line-in to add a phono section to, and the Benchmark does not have that capability.
Enter the Monarchy.  On the surface it appeared to have exactly what I had been looking for.  It is a unique component being a SS DAC, tube DAC and preamp (with one set of line level input jacks) all in one package.  The SS and tube DAC are completely separate from each other.  One other unique thing is that both DACs have their own line level outputs for use with another preamp if one wishes.  There is a button to select either the tube DAC, or the line level input.  The SS DAC is not selectable.  In order to access it you connect its line level outputs to the preamps line in.  Then you can switch between them and compare.  A bit odd, but certainly an interesting arrangement and very versatile.
So far I like the preamp section.  It is much better than my current Audio Research.  I experience about the same amounts of haze being lifted away as I did with the Placette Audio passive volume control.  Which one is better?  I really don't know.  I will be able to do an actual in house comparison a bit later on.  But, as it is now, I am happy with what it is doing.  My AR preamp has a nice phono section to it.  So I connected one set of tape output jacks to the line in on the Monarchy, and was not disappointed.  I also connected the solid state DAC outputs of the Monarchy to a spare line in on the Audio Research.  That allows me to select that through the ARs passive selectors to be routed to the Monarchy line input.  That is not the ideal way to do this, but as I found out, it seems to work just fine.
I found the solid state DAC on the Monarchy to be the closest to the Benchmark in sound.  It seems very precise and accurate in a solid state sort of way.  I am sure that will improve even more with a more direct connection being used, or with the use of coupling transformers as is recommended by Monarchy.  The tube DAC through the built in preamp is where I have spent most of my time listening.  The sound is more forward than with the Benchmark.  Everything appears a bit larger, wider and closer to the listener.  This works well in my system and I don't have any issues with that.  Where the Monarchy seems to excel passed the Benchmark though is with the midrange.  It is very liquid and musical.
From reading through some of the previous reviews most feel that the stock tubes do hold this unit back and there is more potential to be had.  To be honest, I could live with things as they are now, as is often the case until there is a side by side comparison with something else :).  But, in the future I do plan on experimenting more with both different tubes and with the solid state part of the Monarchy.  It is nice having a choice between the two, along with all the rest of the built in versatility.
mr_bill
Re: Monarchy NM24
« Reply #1 on: 23 Sep 2007, 04:24 am »
Does the new NM24 have a remote volume control?
Bill
Housteau
Re: Monarchy NM24
« Reply #2 on: 23 Sep 2007, 12:50 pm »
Unfortunately Bill, there is no remote control.
My normal listening levels has it around the 9 - 10:00 position.  I plan on speaking to the designer to see if there is a way to reduce the gain and allow that pot to have more rotation.  Most find that the less choked back the signal on preamps, the better.
low.pfile
Re: Monarchy NM24
« Reply #3 on: 24 Sep 2007, 07:10 am »
housteau,
Tonight was my first listen through the preamp. Definitely has a different character. My system is very different than yours..... digital computer source/Denon AVReceiver@130wpc/Tetra bookshelfs and sub small room. I've had my NM24 for about 1 month, I am on the 3rd week of breaking in venhaus pulsar w/silver plug IC (to receiver). To use the NM24's preamp section I had to use the only other quality IC I have: a new audio art IC-3s (copper) ideally the two ICs would be identical. I wanted to buy a short length venhaus jumper for the preamp but could justify a $200 test.
Overall I agree the mids are more pronounced and fuller. In my system the highs seemed more tame using the preamp compared to just the tube stage of the DAC. (that could be the audio art copper IC??) I am using a test CD that I am very familiar with and use for auditioning and adjusting my system.
During this listen my in room sound level at about 70db- I have the gain  knob set at mark #4 or just past.  I am surprised that I have to turn my amp up about 5-8db higher to get to the same level as normal -- I thought it would be lower but since I am only about 40% preamp gain it makes sense-I think? Trying higher gain setting on the preamp I get some distortion I had the amp turned down to about 50db when I tried that.
I'll leave it like this for a while (break in the audio arts IC) to see what I think.
enjoy the music ~ed
housteau, BTW you need to click the "Publish this system" link in the systems section -- you are sort of in limbo therefore your system is not visible to others. I saw your set up in your photo gallery.
Housteau
Re: Monarchy NM24
« Reply #4 on: 24 Sep 2007, 08:57 pm »
Since your Denon is an AV receiver and if I understand you correctly, you are connecting the Monarchy preamp out into the Denon and actually preamplifying it again?  Or, does your Denon have a bypass where you can connect directly into the power amp side of your receiver?
« Last Edit: 24 Sep 2007, 10:38 pm by Housteau »
low.pfile
Re: Monarchy NM24
« Reply #5 on: 24 Sep 2007, 09:24 pm »
housteau, I am essentially double preamping, huh? I hadn't done any A/B listening tests since I did the switch around 11pm last night.  I highly doubt that I can bypass the denon preamp for inputs (the opposite is available). No plans for a separate amp at this point. It wold be great to have a spare amp laying around, but alas..... I will return to just the tube dac output. thanks for the heads up.
~ed
Housteau
Re: Monarchy NM24
« Reply #6 on: 24 Sep 2007, 10:41 pm »
Back at ya, for letting me know that my system link was not properly published :).
