Can someone give me an example of a bass traps that would be appropriate in a room like this? Maybe my prejudices are clouding my vision.
ok...I've noodled on this a bit more.Here's where we stand:1. The window (effectively 6' x 7' with a 3' arch on top) will be covered with Pollywood shutters.2. Next to the window, mounted 18" from the floor will be 2' x 4' x 2" high-density (6-7#pcf) glass fiber panels.3. On the side walls, mounted 18" from the floor will be 4' x 4' x 2" high-density (6-7#pcf) glass fiber panels.4. In the corners, and mounted on top of the high-density (6-7#pcf) glass fiber panels will be 4' quarter-round bass traps.5. Behind the desk, mounted 18" from the floor will be a 4' x 4' x 2" high-density (6-7#pcf) glass fiber panel.6. On the floor will be a 5' x 8' rug.7. Various bookshelves filled with CDs, vinyl and books.8. Speakers are positioned on intersecting ratios of 1/5th width and 1/7th length or 1/5th width and 1/5th length.9. Listening position is between 6' and 7' away from the speakers. I'm assuming this would be considered "near field" (I think near field is the only option in this room).I'm really appreciating the feedback...thanks for all the suggestions. Any other thoughts?
Overall that looks like a good start.I would disagree with a reflective layer on the bass absorbers - especially something as rigid and thick as the concrete forms. That room is so live that the little extra upper mid and high frequency absorbtion that they would provide will likely be welcome.Bryan
I'd recommend taking the 2x4 panels that you have butted in the corner by the quarter round and moving it back along the wall a bit to cover your reflection points. This will also make the same amount of absorbtion more efficient by better distributing it in the space.Bryan
