0 Members and 1 Guest are viewing this topic. Read 117578 times.
I haven't made a post in this thread for almost 3 months. Yet, when I look at the traffic logs, I see where there are still lots of folks reading this every day. I suspect that many of them are being linked to here from some other discussion, on some other forum. Anyone care to clue me in?Thanks,Pat
I guess none of them have looked at the noise on the output of the SMPS. I can not see how changing the outboard supply will affect that. Yes, the input to the SMPS will be different, and quite possibly affect the sound in some manner. However, it is a bandaid.Myths die hard in this business.Thanks for your input. (Also explains why a lot of the traffic comes from Australia.)Pat
So an outboard power supply change to an upgraded linear supply would not make a difference in sound whether you use digital output or analog output of the SB3?
QuoteSo an outboard power supply change to an upgraded linear supply would not make a difference in sound whether you use digital output or analog output of the SB3?An upgraded linear supply (mine is CI VDC-SB) WOULD MAKE a BIG difference in sound at least in my system whether you use digital output or analog output (I have not tried this since SB DAC sounds horrible to me) of the SB3 (mine is modded with SC947-02) and/or SB2 (modded with Newava). IMO if you could modify or tweak around with your external DAC you will get the sound you expect.
Quote from: tanchiro58 on 20 Dec 2007, 05:22 pmQuoteSo an outboard power supply change to an upgraded linear supply would not make a difference in sound whether you use digital output or analog output of the SB3?An upgraded linear supply (mine is CI VDC-SB) WOULD MAKE a BIG difference in sound at least in my system whether you use digital output or analog output (I have not tried this since SB DAC sounds horrible to me) of the SB3 (mine is modded with SC947-02) and/or SB2 (modded with Newava). IMO if you could modify or tweak around with your external DAC you will get the sound you expect. It would be great to hear any comments on how you like your CI power supply for the SB3. I would be very interested in hearing about this upgrade from the walwart ps.I have had a SB3 with a Benchmark Dac 1 and really like it, but am reconfiguring and wondering what Dusty's power supply sounds like with an SB3 analog output.Thanks,Bill
http://www.audiocircle.com/index.php?topic=44661.0
Tan: What kind of mods does your SB3 have. Digital? Analog? Or the whole nine yards. Cheers Charlie
Tan: Thanks for the info. Wayne modded my SB3 digital and I have no idea what he did to it. But things do sound good with the SB3 hooked up to an APLhifi DAC. Won't hear me complaining about the sound. Cheers Charlie
No comprende?? What are you trying to tell this dumdum???
How much is the hologram power supply and how do you buy one?
You guys are going to spend $800, Aussie, on an outboard power supply to drive a $300 doo-hickey that has a ratty SMPS inside!?Are you all meshugah? Pat
You ain't see nothing yet!!! Some people here has spent over $1,000 USD on a power supply for their doo-hickey.
