Lemme guess.........you are using a 1 meter pigtail.
Quote from: art on 10 Feb 2008, 06:43 pmLemme guess.........you are using a 1 meter pigtail.Pat, was this one for me? If so, I am not. Remember, I'm in the business too. I'm using a 2 meter SM Corning Cable with the best ST connectors they offer and ends prepped and polished for the lowest possible reflection. I specified quite precisely what I was looking for and they supplied it. Fortunately I paid a realistic price for it, not what it would have gone for in the audio market.
No idea what most of the members there think of me. Guess it helps to know the language. Oh, well.Pat
This is the most informative and interesting thread I've found on Squeezebox mods.
I'm going to mod both my receivers adding the BNC and S22083 transformer in one and, in case I can't get the voltage/impedance output right, will only take out the ferrite bead in the other. Then I'll compare the two.I've read all the posts over the 3 years several times but a couple of things still aren't clear to me.According to Pat's advice, should the 0.22uF DC film blocking cap be connected in series with the 249R resistor before or after the transformer primary at pin 1? I can't see a consensus from the two circuits posted by different members.
Did Pat advise putting a ferrite bead on the positive supply voltage of the HCU04 or was this a further modification?I will appreciate advice to get it right.
