Off topic...any HTPC server guys in the audience? I'm looking at the idea of designing a line of computer cables for network, usb, sata / esata, and power. Does this sound like something you guys would be interested in? I already designed the network cable and notice a small improvement in web surfing / download speed and a major audiophile / videophile improvement in sight and sound compared to the typical Cat5e / Cat6 cabling. I teamed up with Shakti Innovations for this project. I expect the pricing to be around:
3 feet - $60
7 feet - $66
14 feet - $75
25 feet - $88
Do these prices seem unreasonable considering usb cables are starting to be priced around $500? I pledge I will never sell a $500 usb cable, but the mark up on the network cable is almost nothing. The cable spec is 24 AWG 1.5Ghz. The improvement over the standard cable is remarkable, I wouldn't go through the trouble to start up the debate if I wasn't super impressed. If the concept and pricing seem acceptable I will go ahead and invest the time and money into a usb design. Look forward to your feedback.
BTW...the PE Mini will be available shortly. The Mini is half the size of the standard PE and works great with digital alarm clocks, coffee makers, lamps, etc. The price will be $40 per filter.
1 - $40
4 Pack - $160
8 Pack - $320
The mini will be ready for mid-August.
One more thing since I brought up the pc cable idea, in the next couple of weeks I plan to build a audiophile cd/dvd-rom usb transport if anyone is interested in me documenting the project. I have done this before and it worked great, but I wanted to try a new drive and case option....tough to do because most new burners are hunks of junk, but I'm hard at work putting together a affordable Newegg / Parts Express / AM designs part selection. For the moment I settled on the Pioneer 115D drive with a aluminum Bytec case. The power supply is built into the case allowing standard audiophile power cords to be used. I will also be using a Hammond 193L in the basic design. Still need to select the shielding, this is always trial and error, and a good quality foot. Weight matched Vibrapods have always improved read and write capabilities in my previous projects, and Vibrapods gel nice with the Hammond tweak....we'll see. The main cord will be a toss up between the Reference and Studio Reference Jr., all depends on the sound of the Pioneer after it has been tweaked.
HTPC tip: Install a pair of Shakti On Lines on the main 20 pin / 24 pin power cable. Place 1 On Line at each end of the exposed cable, so that means butt 1 On Line up against the psu case and a second On Line at the end of the wire bundle before the bundle widens to enter the molex connector. Allow the pc 3 days to readjust and watch out...it will become rock stable, lightning fast, and improved audio and video playback. Another great tip is to glue a couple sheets on ERS to the case under the motherboard. The ERS will help choke the ground lines in the board and improved system performance. Another thing to try wrapping the fan molex clip is a dual layer of ERS and apply electrical tape or heatshrink for insulation. Take all the fan power connectors off the motherboard and power direct from the psu. You will be able to hear the noise drop out of sight from each wrapped molex connector, the fan will also shows signs of improvement by lower mechanical noise and increased rotation speed. This trick has worked in every pc that I have built over the years...good stuff.
