zmanbands-
The Reference will require 25 to 30 days of non-stop 24/7 electrical flow for a full break in, I suggest turning the component on and leaving it on. Listen to the cord at day 1, 7, 10, 14, 21, 25, and 30 and compare notes.
Note: We have a new Reference power strip coming out in July/August which includes the Reference as the main power cable. I don't think Alan made up his mind yet which strip he wants to modify, better to ask him next month.
michaelv-
The Ref One is too much of a good thing to use on the same circuit as a Hammond choke tweak, try the Ref One on another circuit on the same phase. For those who do not use the Hammond tweak the Ref One will be fine on the same circuit as the a/v system.
vett93-
Thank-you.
The PE V S/AC would be perfect to enhance/upgrade your Shunyata Guardian power conditioner. I would also recommend tuning the non-audio/video circuits using the PE, PE II, III, and Reference One as an option for further improvements in the future
The PE V S/AC will improve every aspect of the musical performance.
I have no experience with the X10 units, maybe one of our other clients can comment. The standard PE and PE V S/AC work above 120KHz, so I don't really see a major problem, but I would still like to see someone comment just to be sure.
Paul-
The Reference and Reference v2 (soon to be released) would be an excellent choice for your system.
denjo-
Dennis when are we going to work out your install problem? As I mentioned earlier the Studio Reference is not a dark sounding cable, it provides a flat response and allows all the tonal quality of the component to emerge, so something else must be wrong. Provide a full list of components, tweaks, cables, speaker positions, and room dimensions, I bet the farm that one of these parameters are out of whack and need to be readjusted.
