Steve-
How is the latest filter working out for you?
Paul-
Do you need further assistance?
BN-
The Ti-Shield tweak is used to shielding the inside of the outlet box. My husband reminded me this tweak can be done three different ways, pending DIY user comfort.
1. Make one case to cover the inside of the wall box. Ground the Ti-Shield box with 12ga copper wiring.
2. Make a custom shield for the rear and sides of the duplex outlet. Ground the shield to the wire connection of the duplex.
3. Wrap the A/C Male plug of the main power cord and ground the shielding to the ground terminal inside the A/C plug. Use 12ga solid core copper for this tweak. Wrap the bare copper wire around a brass screw nut post. Punch the shielding to add the screw nut combination. Before applying adhesive lined heatshrink, use a Dremil to cut off the excess screw length. Alan also recommends adding a pair of Shakti On Lines to the power cord for this tweak, the combination offers huge tonal upgrades across the musical spectrum. This combo is much better than the Highwire Power Wrap idea. Please contact us for Shakti products.
Michael-
Any outlet on the circuit can be used as duplex 1. You could have 9 duplex receptacles on the circuit, but only want to use 5 of those outlets, all you need to do is pick 5 outlets that fall in line with the suggested set up in reference to your system duplex location on the circuit.
Big Red-
Projector application: single outlet use the PE. Single outlet with monitor liberator, use a pair of PE II's, another option is to use a PE and PE IV combination. The pair of II's add sharpness, depth of view, and enhanced color and hue. The II and IV combo add additional enhancement to inner detail and depth, enhanced color and hue over the II combo. The new Reference power cord does wonders for projectors, I would consider the power cord before the filter, you may find the filter not required. The Reference chokes the line and offers superb noise rejection and suppression. Longer lengths (anything longer than 5 feet) offer even more noise rejection compared to the standard 5 foot length. The Reference can also be custom ordered for in-wall applications. Try to keep the lengths under 30 feet because the geometry is done by hand and is very labor intensive and time consuming.
Adamay-
The Nuforce amps are a funny animal. The amp has a lot of room for tweaking, the PE series can offer exceptional improvements in performance. I would recommend a pair of PE II's, one PE IV, and two PE III's if you would like to designer a warmer sounding amplifier. If you need to thin the sound out I would suggest replacing the PE III with our standard PE. I also recommend our new Reference power cable. The Reference does wonderful things to enhance lower midrange warmth, depth, and organic textures.
We are now accepting pre-orders toward the next batch of filters and power cables. Alan will be back to work March 21/22. The next ship date is the week of March 24-29.
