parallel or series/parallel?
FredT300B
Re: parallel or series/parallel?
« Reply #20 on: 14 May 2008, 03:12 pm »
If the distribution amp sounds musical then this would be a good solution.
Of course this approach would require an active crossover (building a separate passive for each two drivers would be impractical). I haven't heard this amp, but it's the one Linkwitz recommends for use with the Orions, so I would expect it to sound ok - probably comparable to Rotels, Parasounds, etc., but without the gold RCA's and other audiobling.
Jose R.
« Reply #21 on: 14 May 2008, 05:17 pm »
Apologies for what may be a stupid question.  If one uses a parallel array which results in a very low overall impedance, is it possible (or beneficial) to add a series resistor in order to increase the overall impedance.  Is there any benefit or drawback to this approach.
Regards
Jose
Andrikos
« Reply #22 on: 14 May 2008, 05:23 pm »
The series resistor will eat up the power and blow up if it's not the right rating.
Assume a // driver combination of 1ohm and a 1ohm series resistor to get 2ohm impedance.
Half the voltage (and therefore power) will drop across the resistor.
This way you're losing half the power into the resistor.
Not a good idea.
Jose R.
« Reply #23 on: 14 May 2008, 06:29 pm »
Thanks Andrikos
I accept that one will lose some voltage but so would an arrangement where the drivers are wired in series/parallel for an overall impedance of eg 4 or 6ohm.
Would the resistor adversely affect the sound?
Regards
Jose
