Squeeze box modification output cap, if one.
0 Members and 1 Guest are viewing this topic. Read 1528 times.
« on: 3 Sep 2007, 02:31 pm »
Just wondering what value of output capacitor is used when squeeze box is modded, if one is used? Maybe a range of values from different companies?
Thanks.
mgalusha
Re: Squeeze box modification output cap, if one.
« Reply #1 on: 3 Sep 2007, 09:28 pm »
Steve,
I think most folks use 3.3uF or larger. It's not optional since the DAC in the SB is single ended it has a few volts of DC on the output so a blocking cap is required. I can say that a 3.3uF Sonicap bypassed with a VH Audio V-Cap works very well, better than the same 3.3uF cap with a Sonicap Platinum as the bypass, at least to my ears. :)
Value wise, it's just your standard 1st order high pass, so the cap just needs to be large enough to keep f3 low. With the SB3, there isn't enough room in the case for a large film cap like the Sonicap I'm using. The small BG NX's with a film bypass work pretty well though one could probably get a low voltage 3.3uF (or so) film cap in there but maybe not a polypropylene.
Mike
tanchiro58
« Reply #2 on: 3 Sep 2007, 11:47 pm »
You might also get a pair of Black Gates Non-polarized NX-HiQ 47uF/6.3V electrolytic caps based on Gary (GNN). Check it out in this forum.
« Reply #3 on: 4 Sep 2007, 12:40 am »
Thanks guys. Is 3uf a bypass or the actual full coupling capacitance?
If we are talking full capacitance, I would prefer the 47uf blackgate to be safe for low input Z components. The 'rule of thumb' I have seen is not all that accurate.
Thanks again.
« Last Edit: 4 Sep 2007, 06:18 pm by Steve »
