PLC-1 Remote Passive -- Discrete on/off codes?
ctviggen
« on: 2 Sep 2007, 10:12 pm »
Are there discrete on/off codes for the PLC-1 remote passive?  (Discrete on/off codes are basically essential for a programmable remote.)
Thanks.
CIAudio
Re: PLC-1 Remote Passive -- Discrete on/off codes?
« Reply #1 on: 4 Sep 2007, 04:00 pm »
There is no on/off function (the unit is on when plugged in).
I don't know if most programmable remotes will work as we do not use standard RC5, NEC, etc. codes. If your remote learns/duplicates the pulse code, then it should work.
ctviggen
« Reply #2 on: 4 Sep 2007, 04:40 pm »
Thanks, that makes sense.  I was under the impression that there would be an "on" and and "off", but since there is not, that makes programming the remote easier!
