Nitrogen in car tires?
0 Members and 1 Guest are viewing this topic. Read 5286 times.
Bob in St. Louis
Re: Nitrogen in car tires?
« Reply #20 on: 4 Sep 2007, 12:09 pm »
Maybe we should use Helium (non-explosive, lighter than air).  This would reduce overall weight for better performance (acceleration, economy, braking) and unsprung weight for better handling.
For all the fluff the marketers put into reducing a few pounds here and there, this could be relatively legitimate.
Yup
Helium could be great too.
It's lighter than air, therefore makes your car weight less, hence better fuel economy. :|
mcullinan
« Reply #21 on: 4 Sep 2007, 01:40 pm »
I like the helium idea and think it would float -badum dum- if it wasnt so thin, I think it would leak out of the tires quickly. Of course I looked none of this up and am going on my pure genius to support my hypothesis.
Mike
CSI
« Reply #22 on: 4 Sep 2007, 01:42 pm »
Hamer & Jones Tire Co. in Long Beach CA were putting nitrogen in performance tires back in the Sixties, so nothing new here. Since this is an audio forum...aren't there islolation platforms out there that use air bladders? I can't wait for a group of serious guys to listen and report on the difference in "sound" between Iso air bladders with nitrogen vs. plain air.
"Imagination, is silly....."
doug s.
  • makin' music
« Reply #23 on: 4 Sep 2007, 06:45 pm »
this topic came up a coupla weeks ago on the alfa digest.  bottom line - don't waste your money; completely not worth it unless you're gonna be tracking your wehicle.  and you should be able to find someone to do it for a lot less than $8/tire.
ymmv,
doug s.
MikeC
« Reply #24 on: 4 Sep 2007, 08:08 pm »
I went to Nitrogen last year as it was offered free with my new tyres (in South Africa). I don't think I would have paid anything for it, certainly not $8.00 per tyre. I also just drive in to the tyre shop to get the pressure checked and the tyres topped up periodically, also for free. I can't say there is a radical difference in mileage, but I have got less tyre wear at an equivalent mileage than previously. I also virtually never need to add any Nitrogen, and I do run my tyre pressures at about 10% over factory spec in my Subaru. As pointed out, the primary difference is that the Nitrogen is almost completely dry, resulting in less expansion (increase in pressure) with temperature change.
Helium would not be a viable option. It is the smallest size atom or molecule, as it normally exists as a discrete atom. Hydrogen, apart from being highly reactive, exists as a molecule (H2) and is thus a larger "particle" than Helium, although it has a lower atomic number. Because of this, Helium is used as a medium for detecting leaks, as it diffuses through any gap faster than any other medium. I used to detect leaks in components by charging them with a 10% Helium mix in Nitrogen at 40 bar, and testing them in a vacuum chamber using a Helium detector. Everything leaks, it is the leakage rate that determines the pass/fail of the component. Basically, this is a long winded way of explaining that Helium would very rapidly leave you feeling deflated. For another example, compare the rate at which a party gas filled balloon (Helium/Nitrogen mix) rapidly loses pressure initially as the Helium diffuses through the rubber.
Regards
Mike
