0 Members and 1 Guest are viewing this topic. Read 31583 times.
What type of surface does the reflecting? Plywood, a composite, hard foam?
I don't think we suggested that your products did not work. Anything that one can do to kill a corner and it's horn effects is a positive thing. Also, PROPERLY absorbing sound does not end up with rolled off frequency response. I think if you look at the specs on both the GIK and the Real Traps, you'll find that they're specifically designed not to overdo it.The thing that is of concern is that the bass control seems to be ignored. That is just as or more important IMO. THAT's why a lot of rooms sound dead and rolled off - because it's a bunch of upper mid/high frequency only absorbtion with the vocal range down basically left to run wild causing an imbalance in decay time through the room.Bryan
The Adapt products show measurable improvements down to 40 Hz.
The Radio Shack SPL meter is not as accurate as it should be, you should take the following into consideration when plotting your curve.http://www.subwoofer-builder.com/SPL-corrections.htm
I don't think any 1 product is a cureall for all room quirks.
IronLion wins the prize of course. As I've consistently stated, the Eighth Nerve products are NOT designed to be absorbers. They are designed to trap most of the corner return wave. That alone reduces echo and reverb, and flattens the frequency response. They are not absorbers at all in the general sense, so therefore do not suffer from the most egregious side effect of every other acoustic product, over absorption of high frequency information. As you should be able to see from my diagram, the whole "trapping of the corner return wave" is not a gimmick or feature of the product, it is the product.So if your idea of great acoustics is rolled off high-frequencies and tons of huge panels on the walls and century old science, then by all means believe that size is all that matters. After all, that's "how acoustic products should work."Sorry for the glib response, but as you can see from the responses (no pun), they do in fact work and they work well. Years of unanimous positive feedback supports this, as well as technical measurements. Glenn and Ethan, you guys do a great service here helping people out with acoustics. There is no reason to suggest that my products are somehow not effective because they don't work like yours. I'm not selling snake oil, there is real science behind these designs. You won't find it in Everest's tome because it's not old science. Can't we all just, get along?Love and kisses,Zaphod
In decay time?Again, I'm not bashing the product in any way. Many people have the product and they like what it does. I don't believe I've ever said any different. I just want to consider all of the things that are key to improving room response. Frequency response is just one. Overall decay time, balanced target decay curve, impulse response, etc. are also important elements of a balanced treatment plan.Bryan
Quote from: 8thnerve on 28 Sep 2007, 08:42 pmThe Adapt products show measurable improvements down to 40 Hz.Nathan, I don't want to seem like I'm bashing you either, but I'd like to learn more about the test data you show on your site because it makes no sense to me. Looking again at the data on your Methodology page, the peak and null frequencies are not exactly the same for the before and after graphs. They are similar, but at 80 Hz there's a null without treatment and a slight peak with. The only way I can see that happening is if the measuring microphone is moved between tests. In which case the entire test is invalid.Do you have more detail you can share about how the tests were done, photos of the room showing microphone and speaker placement, software used, and so forth?--Ethan
I don't have any photos, but the Phonic PAA2 used was mounted on a tripod at the listening position, and the small amount of treatment was measured with white noise and averaged over 4 subsequent readings.
I would love to have new measurements done at an independent facility, unfortunately, all testing facilities are designed to measure absorption ability, not overall frequency and phase data as a systems approach.
Quote from: 8thnerve on 1 Oct 2007, 01:20 pmI don't have any photos, but the Phonic PAA2 used was mounted on a tripod at the listening position, and the small amount of treatment was measured with white noise and averaged over 4 subsequent readings.The key is if the microphone was moved between tests, which you didn't confirm or deny, and also the resolution of the measurements. Could you please elaborate a bit more? I'm sure I'm not the only one here who is fascinated by this stuff! Also, I agree with Glenn that you really need to have your products tested formally in a lab. You wrote:QuoteI would love to have new measurements done at an independent facility, unfortunately, all testing facilities are designed to measure absorption ability, not overall frequency and phase data as a systems approach.I'm afraid I have no idea what that's supposed to mean. If your products can improve the decay times and frequency response of a room, I assure you this can be measured by an acoustics lab! Heck, I will gladly measure your products for you, just as I did for the Cathedral Panels guys. However, my tests show only a change in response and ringing, not absolute performance values. Which is why acoustic labs exist. So unless you have truly invented a "new physics" (unlikely), I can't see why your products couldn't be tested at a lab just as all other room treatment products are.--Ethan
Changes are being made to the room this week. No sweeps yet (assuming I can get them done properly). Preliminary listening is good.
I've been on the lookout for better software for measurement, specifically one with phase options and speech intelligibility. Have any recommendations?
