0 Members and 1 Guest are viewing this topic. Read 7444 times.
...Dave Dlugos makes some flat pack kits and is a source of great deal of info on full range driver diy projects. Here is his site:http://www.planet10-hifi.com/...
...I think the Aria you have selected would be a wonderful project - I own both the WR125S and FR125S, and should I ever decide to take apart the 2 sets of speakers they are in, and build another, that would be the place I would reuse those drivers....For a simple start, I would suggest an FR125S in a sealed box of about 0.5 cubic feet. Then, you can experiment with porting that box to see what the bass difference is. Then you can consider buying the additional parts to build the Aria. All that playing around will teach you the mistakes that YOU will make, when building boxes etc, and trust me, your 3rd try is SO much better than your 1st!I would be happy to lend you some drivers etc, if you want to get your feet wet first, just playing with sawdust for free...
I have built (OK, Daygloworange BUILT them, after I lent him the drivers! Thanks again Denny!) a simple sealed FR125S speaker, and it does surprisingly well.
HI,Check out this site:http://www.frugal-horn.com/index.htmlDave Dlugos makes some flat pack kits and is a source of great deal of info on full range driver diy projects. Here is his site:http://www.planet10-hifi.com/
