VDC•SB Update (Squeezebox Power Supply)
CIAudio
Re: VDC•SB Update (Squeezebox Power Supply)
« Reply #40 on: 13 May 2008, 06:01 pm »
Are the SB power supplies in full production now? Is there a waiting list, or is there likely to be a bit of a wait?
VDC•SB is in production and in stock.
VDC•9.0 for Duet is also in stock/$279...but not yet on our website.
bacobits1
« Reply #41 on: 15 May 2008, 01:28 am »
Can this power supply be used on a Trends 10.1???
Someone else said , yes.
The output is 14VAC. The Trends uses 12VDC.
D
satfrat
« Reply #42 on: 15 May 2008, 01:37 am »
D
I think I already answered that question but here ya go again,,,,,
Wayne Waananen  of Bolder Cables helped me out on this one. He says this power supply is totally compatible with the Trends UD 10.1 USB Converter. Even tho Wayne thinks the modded ELPAC would give a slightly warmer analog-like sound, my order will be placed for the Channel Island power supply.
I've been using the VDC-SB power supply with the Trends UD-10.1 USB transport for a few months now and love the quality upgrade the CI provided over the optional battery pak. I can't be more clearer than that. :D
Robin
bacobits1
« Reply #43 on: 15 May 2008, 02:23 am »
Sorry Robin,
I was talking about the Trends T10.1 amp not the DAC.
My mistake.
satfrat
« Reply #44 on: 15 May 2008, 05:13 am »
Opps!  :oops: :lol:
CIAudio
« Reply #45 on: 15 May 2008, 03:46 pm »
The VDC-SB will not work for your application...it is 5vDC. At this time, we do not make a 12vDC supply.
snoogly
« Reply #46 on: 2 Jun 2008, 01:13 am »
Will the VDC-9 work with the SB?
Trying to decide which one to buy.
CIAudio
« Reply #47 on: 2 Jun 2008, 01:18 am »
Use the VDC•SB for Squeezebox (5.0v DC)
and VDC•9.0 for Duet (9.0v DC)
