Tan,Thanks for the reply, but I understand what the VDC-SB is/does. My question is how do you have your Squeezebox hooked up to your stereo receiver? I've heard that changes made to the Squeezebox power supply don't make much difference if your Squeezebox is connected to a receiver via digital connections (optical or cable). So I'm curious how your system is setup.
So if I'm understanding correctly, you have a SB2 and a SB3 and you like the sound difference with the SB2 but not with the SB3. Is that correct?
hey guys! i emailed you this question but i figured i would put it in this thread in case anyone else is wondering. i have (and love) the power supply but would like to move my SB away from the unit. can i get a longer dc umbilical (say 10 foot) either from you or if you know any aftermarket (seems to be hard to find custom built dc cords)? any drawbacks with this?
Yes, I use a stock SB3 (digital out) feeding a Altmann Attraction DAC, both units separately powered by a Paul Hynes shunt regulated PSU. It sounds very analog-like and transparent! Best RegardsDennis
Will you be releasing a version of the VDC-SB for the new Squeezebox Duet? (With it's lower power consumption?)
Does anyone out there know if this CI VDC-SB power supply will work with a Trends UD 10.1 USB Converter? I'm thinking it will but it would be nice to confirm this before purchasing one and getting stuck with a 10% restocking fee.Anyone?Cheers,Robin
