Red LED from inside the chassis when power up.
0 Members and 1 Guest are viewing this topic. Read 1895 times.
Baard
  • Touch - Bufallo DAC II - Meridian - Bryston - ATC
« on: 29 Aug 2007, 06:11 pm »
Hello
Have a pair of 7B SST - when power up one amp. a red LED is lightning from inside the chassis for half a second - is it normal or time for service? This is just for one channel - I think.
Baard
« Last Edit: 29 Aug 2007, 06:38 pm by Baard »
  • The Demo is Everything!
    • http://www.bryston.com
Re: Red LED from inside the chassis when power up.
« Reply #1 on: 30 Aug 2007, 03:24 pm »
Hi James;
Could be something a bit strange with the LED driver circuit on that amp.  Hard to say without looking at it.
Mike
Baard
« Reply #2 on: 30 Aug 2007, 08:06 pm »
The same occur for both amplifiers – it’s easily to spot in the dark when powering up the 7B SST.
If you look at the amps from above – and think about geometry, you can see a red flash in middle of first quadrant.
I don’t worry about it – amps performance is stunning I was just curious.
Baard
IronLion
« Reply #3 on: 30 Aug 2007, 08:41 pm »
If you're really curious, this is a question best left to the manufacturer...
Baard
« Reply #4 on: 30 Aug 2007, 10:16 pm »
That’s why I am posting here…
« Reply #5 on: 30 Aug 2007, 10:39 pm »
Hi James;
Mike
Hi,
I should have made this clearer - Mike above is a Bryston factory technician.
james
