AJ, thanks...
Seems like the Servo is for HT duty...I need subs for music, 99% of the time...
How do you lke yours for music?
You have it the opposite way around. These are music subs - with enough output to be used as HT. They sound as good as any sub that size (yes, regardless of price). The servo system is the difference that sets it apart from the usual (DIY) suspects (I've owned/heard tons, including Dayton RS, Peerless XLS, Adire, etc,etc. systems).
I use mine for music exclusively now (TCSounds for HT). That is where they excel. They will beat the pants of many store bought subs at several X the price.
You'll fully understand when you set up a pair in your music room
cheers,
AJ
p.s. you can do a search over on DIYaudio. Several folks there have built these.
