Simple Universal Remote for Audio
0 Members and 1 Guest are viewing this topic. Read 968 times.
Carlman
« on: 22 Aug 2007, 08:10 pm »
I'm looking for a very simple remote, similar to this:
However, this remote, like most, only controls video-related gear.
I have a Musical Fidelity X-150 integrated amp that has volume, input selector, and mute remotely controllable.... I do not have the remote for it and was thinking I'd get a new one.
I'd like a 'skip forward' button for a cd or dvd player that was playing music if possible.  So, that's not a lot of buttons.  If I had nothing but volume up/down and skip forward/backward that would be adequate.  I will find an X-150's remote if I have to but I did not realize what a big ask this was until I started searching for one...
Is there such a thing as a simplistic remote that is programmable for audio equipment?
-C
larryrx7
Re: Simple Universal Remote for Audio
« Reply #1 on: 22 Aug 2007, 08:54 pm »
Look at one from Logitec/Harmony...They are completely programmable from an online database...very cool... I used go have  your amp and cd player also and this remote was great. I have the 659 but there are many other models available
electricbear
« Reply #2 on: 22 Aug 2007, 10:32 pm »
Why not contact Musical Fidelity and get a remote from them?
BradJudy
« Reply #3 on: 23 Aug 2007, 12:42 am »
Don't underestimate One For All - they have a great database of codes and seem to have good customer service.  Write them an e-mail with your list of equipment and ask if it can handle it.
Otherwise, a fully programmable remote is your option, but I don't know of any with such a simple button layout.
Carlman
« Reply #4 on: 23 Aug 2007, 12:25 pm »
Thanks for the advice! :)  I'll definitely email OneforAll... I've had good luck with them in the past on video stuff.. If I can't get a $10 cheapie that works, I'll go the $60-100 route with a replacement MF remote.
-C
