Do PMC speakers benefit from tri-wiring?
0 Members and 1 Guest are viewing this topic. Read 2105 times.
vegasdave
« on: 21 Aug 2007, 01:56 am »
Please advise. Thank you.  8)
Thunder
Re: Do PMC speakers benefit from tri-wiring?
« Reply #1 on: 21 Aug 2007, 09:49 pm »
Absolutely, as well as tri-amping. I've compared vs single and bi-wire. For best results though, use different wire gauges for each driver: 12 for bass driver, 14 for mid range and 16 for tweeter. These are the gauges used inside the cabinet BTW.
vegasdave
« Reply #2 on: 22 Aug 2007, 12:01 am »
I see. How do you triwire...since our Bryston amps have only 1 set of binding posts per channel. I'm thinking spade lugs...
Thunder
« Reply #3 on: 22 Aug 2007, 10:52 pm »
I would biwire the mid and tweeter using a spade and single wire the bass driver using a banana.
As far as the spade goes, if they are thin enough (like the one www.anticables.com uses, you could simply stack them rather than connecting the two wires to a single spade.
vegasdave
« Reply #4 on: 23 Aug 2007, 12:13 am »
Sounds good. Thanks for your help.
Thunder
« Reply #5 on: 26 Aug 2007, 04:47 am »
A correction on the wire gauges I quoted above, you should use 10, 12 and 14.
vegasdave
« Reply #6 on: 26 Aug 2007, 11:57 am »
Thanks again. How about using say, 10 gauge for all 3 drivers?
Thunder
« Reply #7 on: 26 Aug 2007, 09:23 pm »
I wouldn't do that. The larger gauges favour the lower frequencies and vice versa. If you are running a single cable, you essentially have to compromise -- select a gauge that will work well enough for all drivers. A 12 gauge cable would be a good average for the needs of the 3 drivers. The benefit of going with 3 cables is that you can select the right gauge cable per driver, you don't have to compromise like you dio with a single cable. Hence, I would go with 10g for the bass driver, 12g for the mid range and 14 g for the tweeter.
vegasdave
« Reply #8 on: 28 Aug 2007, 06:11 am »
I see. Thanks again.  8)
