FS: SKA GB150D/GB150S2/SKPre/Dual Reg
0 Members and 1 Guest are viewing this topic. Read 1644 times.
goskers
« on: 19 Aug 2007, 01:38 am »
Hello All,
I have purchased the listed parts from Greg Ball of SKA (Simple Killer Amp).  As most probably know, Greg has been designing audio equipment for a long time and has hit the US with his outstanding amp modules.  I purchased the kits listed below and have built them all complete per spec using Cardas solder.  My current workload is forcing me to sell the modules and power supplies prior to finishing them.  Hopefully someone will find great usage out of these as they are supposed to be outstanding values.
Listed are the quantites of various products.  Again, all these boards have been fully stuffed using Cardas quad solder.  All prices are 20% less then the kit price alone.  I think that is very fair.  Pics can be had by request.
(4) GB150D mono amp, 285$ for all four.
(2) GB150S2 power supply for two GB150D modules, 126$
(1) SKPre preamp module, 53$
(1) Dual Regulator power supply, 53$
If interested, I have a couple chassis that will work well with the amp modules and power supplies.  My plan was to use the quad set on the upper portion of the Linkwitz Orion.  Heatsinks for the amps are also available.  I would really like to sell everything together.
For additional info please browse the SKA site: http://www.ska-audio.com/
J@ck
Re: FS: SKA GB150D/GB150S2/SKPre/Dual Reg
« Reply #1 on: 19 Aug 2007, 02:06 am »
Hi
Your inbox is full.
I am interested in assembled units. Could you please give me some photos of the cases you have for them? How much would you want for assembled units?
Also are you locate in USA?
Thank you.
goskers
« Reply #2 on: 19 Aug 2007, 10:45 am »
Sorry about the full inbox  :duh:
Please PM me and I can get you some pics later today of chassis, heatsinks and modules.
If you could clarify exactly what you mean by 'assembled units' I would appreciate it.  Everything listed in the FS ad is fully a fully stuffed board.  To complete a two channel amp you would need one of the GB150S2 and two GB150D, a chassis, transformer (which I just remembered that I have as well) and wiring.
Send me a pm and we can workout the details.
