0 Members and 1 Guest are viewing this topic. Read 21498 times.
...The problem with the remote system is what pots does one use? All pots are not equal. I cannot use an inferior pot in my designs and stay accurate to the music.Individual pot sections are matched in a single pot. However, differences between two separate pots can be quite high when considered on a rotational basis. So when changing volume, the balance can be off, necessitating a manual adjustment.I have multiple methods of testing (took years to develop and are proprietary) my preamps. Those methods are quite different than simply 'voicing'. I do not want to degrade that sound for convience sake...
In case Wooodsyi didn't mention it, the 4B (Bolder/Bent/Burson Buffer is a PROTOTYPE unit. One of a kind. It was sent out to get user opinions on the interface and on the sound.
Can you expand on the statement "And I'm still not ready to consider a computer hard-drive as a source for my music". ?thanks,WEEZ
doug,If one channel indicated it was higher, then the "balance" control must of been moved by mistake at one point.The unit uses two separate boards, one for each channel, for volume control. The remote control will let you "balance" (adjust) each channel independently. That is the reason for two separate displays of "volume".The + & - buttons control volume and the horizontal arrow buttons control balanceDid you guys change the phase of the system between the listening to tube pre-amps and the B4? Most tube pre-amps that I am familiar with invert phase. The B4 does not.Rim, you might want to give this a try if you have time in the next couple of days. listen to the B4 with your speakers set up the way you have them now. Then reverse the polarity of the speaker wires. Do the same with the tube pre-amps you have on hand. Please let us know your findings.
...If the system sounds sterile, then another component or components in the system are not right, but sterile, too thin, washed out. But it is not the preamp or IC's fault. The sterile component(s) need to be changed or upgraded until the system is neutral/accurate to the emotional event for better synergy. I do not see how an accurate system can sound sterile with using my definition?...
...As far as redbook always sounding sterile, I have a modded Rotel 865bx that does not even have a hint of sterility but 'makes music'. I am sure there are other manufacturer's as well who produce such components. In fact, in stock mode, its problem was a little too smooth and full. I corrected those problems...
...I also have customers who care only for top quality sound, a remote is not necessary. I have to use the best control for the job or I lose those customers...
...Woodsyi made a comment that the differences were minute, nitpicking. In such a case, something as simple as a changing an IC, one internal parts value change, one part from a different manufacturer, certainly a component change would easily change the sound and results, such as the 11A being right on and the Mod sounding too full. I guess one would then rid the Modwight of the after market power cord....
...What I am saying is, don't make too much of auditions. They can only give relative differences and similarities...
