0 Members and 1 Guest are viewing this topic. Read 8923 times.
Thanks for all the comments.
I'm going to venture a guess as to the source of the observed differences between the HT1 and towers. First, the matter of "bloom" almost certainly has to do with the woofers, not the tweeters. As I've commented before, the W18 has a unique midbass presentation. It is, depending on the listener, either extremely realistic, or, alternatively, "thin." I think I belong in the first camp. The CA15's have a little more warmth in the midbass. Overall, I think the CA15 has less "warmth" than most other woofers, but I can hear the difference when comparing the W18 and CA15 under carefully controlled conditions.
Frankly, my main goal with the towers was to maximize bass performance in a small foot-print speaker, and achieve as clean a midrange as possible. I also wanted the highs to be at least very good, which is one of the reasons I chose 3/4" tweeters, but I never expected to equal or exceed the ribbon designs in that department.
If you get a chance to compare some recordings with more instruments (orchestral, say) I'd like to hear about it.
one of my girl friend's favorite things to do is to come over and just listen to music on the speakers for a couple of hours straight
Sounds like you've got something special there, where do I get one.
uhh. i think he was referring to your girlfriend.
Here is a picture of the SongTowers in my room. You can also see the left HT1. To switch back to the HT1's, I would just replace the right speaker.
