0 Members and 1 Guest are viewing this topic. Read 3012 times.
Thinking of buying a tubed Jolida 100 but concerned about the players actual output impedance, which I can't seem to locate.Is this a problem?
"Line Output Voltage: > 2V, 47 Kohms" From Jolida's site.I contacted them about this a while back as it seemed extremely high, they said it is indeed a 47kohm output impedance.Jared
Hi Jared,Thanks for chiming in with this info. 47k output impedance? Well, I can't say I recommend using a 10k passive preamp with that Better go with an active preamp with an even higher input impedance. Or, Jared's Ack Dack for sale would do the trick nicely (that is a great NOS dac and the price is right!): http://www.audiocircle.com/index.php?topic=43793.msg393625;topicseen#new-Vinnie
Walter at Underwood HiFi Mods told me the 47K output is a misprint.The actual impedence is 47 ohms.I guess he should know, he modifies them.Actually, 47K seems ridiculously high for any source.
