First attempt at stitching
0 Members and 1 Guest are viewing this topic. Read 2119 times.
JohnR
« on: 5 Aug 2007, 07:43 am »
I was at Narrabeen Beach today and couldn't get what I wanted into the frame. So I thought why not give this stitching thing a go. Note to self -- next time turn off automatic white balance! I used the free Hugin program (OS/X).
JohnR
Re: First attempt at stitching
« Reply #1 on: 5 Aug 2007, 02:43 pm »
Second attempt... just three frames this time.
Daygloworange
  • www.customconcepts.ca
« Reply #2 on: 5 Aug 2007, 03:22 pm »
Hey John,
Did you shoot with a tripod, or handheld?
Can you briefly describe what you did to get the panoramic shot you posted? Being a little lazy here, I haven't yet attempted stitching...
Cheers
Doublej
« Reply #3 on: 5 Aug 2007, 03:45 pm »
The easy way is to put your camera in stitch mode, fire away and then use the stitch software that came with the camera to put multiple images back together.
I've done it a number of times with a Canon camera by hand. The results for me would be much better with a tripod as I don't do a good job of making sure that each frame has the same vertical alignment.
Daygloworange
« Reply #4 on: 5 Aug 2007, 03:58 pm »
I think I might give it a go this weekend. I haven't even loaded the software that came with my new Canon A5 IS.
Cheers
jakepunk
« Reply #5 on: 7 Aug 2007, 03:43 am »
For you Mac guys, I have found a really great pano stitch program called Calico.  It's a lot easier than Hugin and only costs $39.  I love it because it is fast and easy to use because you don't have to pick the overlap points manually.  You can try before you buy (the demo puts a watermark in the images).
I have had much success with panoramic images without using a tripod, BTW.
JohnR
« Reply #6 on: 7 Aug 2007, 04:40 am »
Cool, I will have to try that out!
I didn't use a tripod, this was an impromptu effort. A tripod would have made stitching easier, as it took quite a few goes before I was able to get the horizon straight...! But perhaps this Calico program will negate that.
Doublej
« Reply #7 on: 7 Aug 2007, 11:18 am »
The Canon stitch program I have works automatically. You just select the photos to stitch and press go.
