0 Members and 1 Guest are viewing this topic. Read 8332 times.
I am not sure if there was any agreement on an official name for this VMPS Reference System. So, I have just been referring to it as a Reference System on other forums.
I am starting to get things dialed in a bit. As Brian had suggest in an earlier post, I have used the single band of parametric equalization in each bass amp to fill in the bottom half octave. I have it set on both channels for a narrow band of + 6db gain @ 18 - 20 Hz. This has me - 3db starting at 18 Hz and remaining +/- 3db up to 35 Hz. I have a 5db peak centered at 37 Hz and a 10 db room mode suck-out centered at 47 Hz.What is interesting is that with the positioning of these bass towers the above numbers are better than when I was using that single Larger sub converted to VSS specs. With that smaller sub the 47 Hz suck-out reach 14db. The 37 Hz peak was lower by 1db, but I needed that single band of equalization with the gain cut 14db to achieve it! So, fortunately the VLAs took care of that 37 Hz peak by themselves and left me that single band of EQ to fill in that bottom half octave.These above numbers will probably get better as I learn more over time, but its not just about the numbers and specs. It is about music and I will have more about that a little later.
Are the bass amps built into the towers or are you using outboard amps?
Given the investment in your system, I highly recommend getting a pair of Velodyne SMS-1 to to better integrate and control your bass.
I wanna hear these at the show
To be honest, I am not sure if I want a completely flat response. I have heard some systems that were reported to be such, and I was not that impressed.
Quote from: Housteau on 3 Aug 2007, 02:10 amTo be honest, I am not sure if I want a completely flat response. I have heard some systems that were reported to be such, and I was not that impressed.Glad to hear I'm not the only one. I flattened my response using Onix's R-DES system a year ago, and I preferred the sound with a non-flat response. I suppose in the real world sound isn't so flat. Your system is incredible. Can't wait to hear your honest assessment of the VLAs.
Given the investment in your system, I highly recommend getting a pair of Velodyne SMS-1 to to better integrate and control your bass.(http://www.hometheaterhifi.com/volume_12_4/velodyne-sms1-digital-drive-sub-manager-12-2005-part-1.html) I recently bought one and used it to just analyze and dial in my bass (my speakers have an 11 band EQ built in). It is pretty easy to use and fairly inexpensive.George
Very impressive, beautiful system you have there. Curious what you are driving the V60's with? Best of luck with dialing it in. It should be a fun and joyful ride.
I believe in working with the room itself first to see what can be done acoustically before adding electronic correction into the mix.
My ears don't seem that sensitive for some reason to this dip, or other dips in general, as long as they are not too broad or too severe. I notice rises in the response more readily. That is why I am also working to knock down that bump at 37 Hz a bit more, although 5db is not really too bad.
Another thing people forget is "flat" is flat at one point, what matters more often with flatness is relative flatness over a broader dispersion into the room. This allows more of a balance of energy into the room which sometimes matter more than on axis flatness. I think it defines a great deal of the tonal balance of a speaker and something I am more particular about than some of the audiophile qualities.
