0 Members and 1 Guest are viewing this topic. Read 11940 times.
Scotty, Thanks for the info. I had planned to make some interconnects also. I have done only a little soldering before. Your instructions should be very helpful. I'll probably order some extra RCA plugs if they are cheap enough to practice on.
Someday I will get around to inventing a Bullet replica that uses ceramic or wood on the outside so it doesn't melt when heated, crack when cryo'd (ceramic might actually, I don't know), or loosen grip with time.
