Pic of copper Cornet with Cinemags
0 Members and 1 Guest are viewing this topic. Read 3281 times.
Bill Epstein
« on: 31 Jul 2007, 09:11 am »
Changed the step-up last night to 350 Ohm 1:9 which is just right for my .3 mV Micro-Ace cart and got a pic while it was open.
Been swapping the rectifier back and forth from Sylvania 5Y3 to Bugle Boy 5AR4. I liked the 5AR4 previously with the stock resistors but now with the Tantalum input and and Kiwame grid stoppers in the mix (thank you, Steve Brown) I think I prefer the 5Y3. Surprising to me how much difference there is.
Gonna take delivery of  a Joule Electra LA-75 pre-amp next week which is supposed to be warmer-sounding than the ARC LS-1 so we'll have to see what tubes go well with that.
Now it's time to finish the Piccolo.
analog97
Re: Pic of copper Cornet with Cinemags
« Reply #1 on: 1 Aug 2007, 12:03 am »
Looks really good.  You had lots of room inside to work!  Please post comparisons between the Piccolo and the Cinemag-Cornet.  I am still on the fence deciding.  Thanks.  Nice work!!
amandarae
« Reply #2 on: 1 Aug 2007, 12:24 am »
Awesome!  Any pic showing the top?  What are the dimensions of the box?  I am thinking of re-doing my Cornet 2 with a Silver chassis which is more robust and heavier.  Your solution will serve as an inspiration!
Thanks for sharing the pic!
regards,
Abe
Bill Epstein
« Reply #3 on: 1 Aug 2007, 12:48 am »
Sorry about the fuzzy pic; I just got home from work and have only had one beer.
Just a $25 10x17 Hammond steel box. If you line it with copper don't worry about heavy!
One word of caution about the EAR Isoloss sandwich mounts: they're so elastic it's almost impossible to push the tubes in w/o supporting the board which means taking the bottom off each time you swap. I'm going to fasten some wooden block supports about 1/4" shy of the bottom of the board to eliminate the hassle.
I drilled the Piccolo box this morning and should have it ready tomorrow nite.
Stay tuned.
amandarae
« Reply #4 on: 1 Aug 2007, 04:20 pm »
Thanks Bill!
regards,
Abe
JoshK
« Reply #5 on: 1 Aug 2007, 04:38 pm »
What kind of copper did you use to line the case?
Bill Epstein
« Reply #6 on: 1 Aug 2007, 06:14 pm »
The shiny kind!
Seriously, it's just 34 ga sheet I got at Hobby Lobby. I didn't know whether to line the box or press a horsy into it with a popsicle stick. It was difficult to get the corners right w/o gaps, snipping a '45', so I made corner pieces to fit over them. The Microsorb damping compound made application really easy but I ran out so the bottom plate has the copper contact glued on.
Your speakers look better than commercial. Arvo Part? I love Part? What do you call the sub, the other Part? I wish I could hear what you've got there. Anywhere near Central Ohio?
I just ordered a set of octal Aikido boards from John for a linestage. Can't wait.
