Can anybody help me in addressing this issue? Should I change Slimserver version on the Mac?
Just put the v15 FW in the correct directory and edit the control file to point to that. The file to edit is squeezebox2.version - make a backup copy first in case something goes wrong.
I'd be surprised if you couldn't change the FW version on a Mac. It should be the same as on a PC. Just put the v15 FW in the correct directory and edit the control file to point to that. The file to edit is squeezebox2.version - make a backup copy first in case something goes wrong.
However, if Slimdevices ties firmware versions to SlimServer versions then this may be a problem.
Are they truly different, or is it simply a ploy to make us Transporter users believe we have something different? I don't know, but I suspect the former.
