0 Members and 1 Guest are viewing this topic. Read 17677 times.
....Review readers please keep in mind that analog cabling can easily alter what you hear through the system. I voiced the dAck! using a silver tri-braid cable similar to the Kimber KCAG. Quite extended highs without being forward, midrange detail without fault, and excellent bass. It's a lively cable, and may be quite different from what Danny is using ...
Will you be at any upcoming Audio Shows ?
I'm aware that with the DI/O some folks have experienced problems with the unit losing lock when play is stopped.
And is it limited to just 44.1/16 bit signals?
hi peak,does this mean yure ready to ditch yer di/o now? i'm strongly considering an audition of the ack! dack!regards,doug s.
....I moved into orchestral and opera recordings, the dAck exposed its weaknesses IMHO. The highs simply did not match the extension and clarity of MENSA. I my deep bass torture test, in went the Gladiator sound track, a couple of organ recordings, and some classic orchestral pieces. While the MENSA excelled with a deep, quick, and clear bass (w/good distinction between instruments) things got a little murky with the dAck. I am ...
