Searching for power strip for my monoblocks 230 V Schuko with iec mains
0 Members and 1 Guest are viewing this topic. Read 685 times.
Frihed91
I am looking for 2 (3max) receptical power strip for 230 volts grounded that has Schuko female recepticals and a female IEC mains connector.
I already have a large filtered power bar, but don't have enough recepticals and I want to connect the second power strip into this one.
I have searched a lot.
rollo
  • Rollo Audio Consulting -
  Make your own. Go to Home Depot and buy some Carrol 10 Ga. cordage wire. Buy a plastic dual outlet gang box and two commercial grade duplexes and plug [ hospital grade is not req. since yu do not need chemical resistance material. the blades are the same size and that is what is important ] and there you go. Just wire together, if you do not know how the tech at Home Depot will tell you how.
  rollo
KCI-JohnP
They have Home Depots in Copenhagen? :o
