Replace fuses in my B100 ?
0 Members and 1 Guest are viewing this topic. Read 1469 times.
eril
« on: 17 Jul 2007, 11:26 pm »
Positive Feedback recommends HiFi Tuning fuses as a simple upgrade.
http://www.positive-feedback.com/Issue32/fuses.htm
My local trusted audio guy also says they are good - smoothing and reducing any glare or brightness.
I have a very bright room, so I need a bit of help in that direction.
What fuses, other than the AC Power fuse (4A - 250v Fast Blow) - can I replace?
What values do they each have?
Eril
niels
Re: Replace fuses in my B100 ?
« Reply #1 on: 21 Jul 2007, 11:08 pm »
As far as I know there is only one fuse you can, and is allowed to change, is the one at the mains inn.
You may try the tuning fuses but when you say you have a hard room I would definetely not think of fuse switching first. The difference might not even be noticeable.
If you have a bright room you put up kelims on the wall, have a carpet in front of the speakers etc.
What other components is your stereo made of ?
