Repair of Perreaux......NYC
0 Members and 1 Guest are viewing this topic. Read 2354 times.
rwd
« on: 22 Aug 2003, 06:28 pm »
I have a used Perreaux 3150B power amp that I believe needs some repair (new caps?). Does anyone know of a real good service Tech in the NYC tri state area?
rkapadia@ROOP
« Reply #1 on: 22 Aug 2003, 10:18 pm »
rwd,
Can you describe the problems with the Perreaux?  Just curious as to why you may think it is the capacitors.
Rup
hmen
« Reply #2 on: 22 Aug 2003, 10:36 pm »
If you feel like coming up to Northern Westchester, check this out. I've used them and always had great results.
http://www.sound-smith.com
vpolineni
« Reply #3 on: 22 Aug 2003, 11:27 pm »
this possible problem dissuaded me from buying a perreaux amp.  check on the audiogon forums-do a search with terms like "perreaux" and "repair"... I remember reading about a guy in california who can repair perreaux amps. hope this helps.
rwd
repair of Perreaux
« Reply #4 on: 23 Aug 2003, 04:36 pm »
My
3150B has two problems: the first is a hum coming from one channel (I can
live with this), the other is something I'm not sure of.  Every once in a
while I hear a sound (sounds like a sneaker scuffing a gym floor??.....).
Do you have any idea what this is?  It is not load, however I'm a bit
nervous.  Any comments?
