Congrats Ethan
0 Members and 1 Guest are viewing this topic. Read 3635 times.
yooper
Congrats Ethan
« on: 14 Jul 2007, 04:56 pm »
On the positive review I just read of the RealTraps MondoTraps in the Aug issue of Stereophile   :thumb:
That is some great exposure!
Mark
Ethan Winer
  • Audio expert
Re: Congrats Ethan
« Reply #1 on: 14 Jul 2007, 06:07 pm »
Thanks Mark. 8)
zybar
Re: Congrats Ethan
« Reply #2 on: 14 Jul 2007, 07:08 pm »
Congrats Ethan!   :beer:
Glowing reviews like this one simply validate what your customers already know...
IT REALLY WORKS!!!!
As for the aesthetics issue...
Just look at my room to see that it can absolutely look nice:
George
ted_b
Re: Congrats Ethan
« Reply #3 on: 14 Jul 2007, 09:12 pm »
Way to go Ethan!  The review puts you further on the map than even before.  We here all knew your products and service were great, and a tremendous value...now everyone knows!   Just like George (although not as beautiful a room) my gallery and system show a significant commitment to Ethan and RealTraps.
Congrats!! :thumb:
Re: Congrats Ethan
« Reply #4 on: 14 Jul 2007, 11:01 pm »
Yes, read the review.  Too bad the dude really down sized his house and doesn't have a better listening room... :scratch:  And he is a reviewer...
Ethan Winer
  • Audio expert
Re: Congrats Ethan
« Reply #5 on: 15 Jul 2007, 04:26 pm »
If you read reviews in these magazines, most of the reviewers who list their auxiliary gear have expensive cables, magic hockey pucks and pebbles, magnetic levitation isolation stands, ad nauseum, but not even one acoustic panel. It kills me when a reviewer who has no treatment at the first reflection points comments on a loudspeaker's imaging. Earth to reviewers: If you don't have at least the reflection points treated, you don't even know what imaging is! :duh:
--Ethan
Ethan Winer
  • Audio expert
Re: Congrats Ethan
« Reply #6 on: 15 Jul 2007, 04:29 pm »
Thanks George. Also, Stereophile asked me to write a Manufacturer's Feedback response, but then failed to print it. Sheesh! So if nobody minds, I'll repeat it here below.
--Ethan
All of us at RealTraps were thrilled to see Jim Austin's great review of our MondoTraps. Room treatment is arguably more important than almost any other component in an audio system, yet it is too often overlooked by otherwise knowledgeable audiophiles. Jim is to be commended for his enthusiastic support of room treatment, and for making clear why it is so important when the goal is accurate high-quality sound reproduction. However, I'd like to address a few of his comments.
Jim noted that MondoTraps are physically large because they have to be. This is simple physics. All room acoustic problems are caused by reflections - peaks and nulls, ringing, flutter echo, comb filtering, excess ambience - all of these are due to reflections. Most domestic rooms have between 600 and 1,000 square feet of reflecting surfaces on the walls, floor, and ceiling. To make a meaningful improvement requires a reasonable proportion of those surfaces to be treated. That Jim obtained such a huge improvement with only three MondoTraps, each having just over 9 square feet of surface, is a testament to how truly effective MondoTraps are.
In a reasonable size room MondoTraps are not as intrusive as in Jim's New York apartment, and the current trend toward dedicated listening rooms helps further. But we also have smaller products that are highly effective. As Kal Rubinson noted in his November, 2006 Music In The Round column, only two of our 31-inch Tri-Corner traps had a huge positive effect in his relatively small listening room.
I'll also mention that MondoTraps do not require "lag bolts" to attach to the walls. All of our products include mounting hardware, which is simply two small Molly bolts and standard picture wire. Interested readers can see exactly what is required for installation in the How To section of our web site www.realtraps.com. For panels that will be mounted flat on a wall they can be hung just like a picture, with only one small hook. We also offer two types of stands to avoid permanent mounting altogether, or to easily move them out of the way when needed.
Finally, in his review, Jim wondered why the MondoTraps improved clarity at higher frequencies since, as he noted, they are primarily bass traps. In truth, MondoTraps are broadband absorbers. In this case we designed them to absorb as much as possible at bass frequencies, but with a controlled lesser amount of absorption at mid and high frequencies. The very specific curve of absorption versus frequency is a huge feature that is unique to all RealTraps products. This way you can put enough of them in a room to truly solve the bass problems, but without sucking all the life out of the room as happens with panels made from foam or plain fiberglass.
Ethan Winer
RealTraps
Glenn K
Re: Congrats Ethan
« Reply #7 on: 18 Jul 2007, 12:17 pm »
--Ethan
That is so true!!!
Glenn
woodsyi
Re: Congrats Ethan
« Reply #8 on: 18 Jul 2007, 12:38 pm »
Congratulations Ethan.  I have magnetic suspension platforms.  aa  But then I also have acoustic panels galore.  :lol: Mondos and others absolutely work.  :thumb:
Ethan Winer
  • Audio expert
Re: Congrats Ethan
« Reply #9 on: 18 Jul 2007, 01:41 pm »
LOL. Okay, but tell the truth now - between the mag platforms and MondoTraps, which helps more?
--Ethan
woodsyi
Re: Congrats Ethan
« Reply #10 on: 19 Jul 2007, 07:53 pm »
--Ethan
Let's put it this way.  Both help but any improvement from platforms and all kinds of isolation devices wouldn't mean squat (can't tell the difference) if I didn't treat the room first.  So my truthful answer:  the room treatment helps more than magnetic suspension platforms in my room.  I would imagine this will be the case in most homes.    :thumb:
Wolfman
Re: Congrats Ethan
« Reply #11 on: 19 Jul 2007, 11:52 pm »
But what if you put the Mondos on top of the mag platforms,hmmm....
Congrats Ethan!!
