spec's for old ACI drivers
0 Members and 1 Guest are viewing this topic. Read 2120 times.
cporada
« on: 11 Jul 2007, 03:27 pm »
Hi everyone
I have a pair of ACI alpha limited speakers (one of ACI's early DIY projects) that I employ as my main speakers and have been slowly tweaking over the years, and am wondering if anyone happens to have a copy of the spec sheets (frequency response, etc.) for the AC5 midrange drivers and AC10 woofers employed in this project, or knows how I could get copies of these.  I've tried searching the web to no avail. Any help would be greatly appreciated.
Thanks in advance
Chris Porada
Mudslide
Re: spec's for old ACI drivers
« Reply #1 on: 11 Jul 2007, 03:37 pm »
Sorry I can't help.  I'd love to get the specs for my set of LX's, as well.  Certainly someone...somewhere...can help us.... :|
Mike Dzurko
« Reply #2 on: 12 Jul 2007, 08:53 pm »
Hi everyone
Thanks in advance
Chris Porada
The good news is I'm sure we have a set, probably two.  The bad news is that the set here at the office is buried somewhere in the archive boxes for the upcoming move . . .  earliest we'll get at that will be August.  I'm pretty sure I had a set at home as well, but  . . .  yep, they would have been packed for that move as well :roll:   I will keep an eye out, but it might be a bit before I find them . . . Then I'll need a number I can fax them to . . .
cporada
« Reply #3 on: 12 Jul 2007, 09:31 pm »
Hi Mike
Thank you so much.  You may not have to go digging; someone from Audio Asylum posted that he has a bunch of old ACI catalogs laying around at his house. He looked up the AC5 and AC10, and gave me the following values:
AC10 Specs:
Xmax .7 (one-way linear excursion)
Power 150W
Fs 23 Hz
Re 6.1 Ohm
Qms 3.6
Qes .5
Qts .44
Vas 138 liters
Sensitivity 89 dB 1 Watt/1 Meter
Recommended Crossover Zobel 33 mfd cap with 7 Ohm resistor
Recommended for Sealed Enclosure
Box Size 1.69 cu. ft
F3 37 Hz
F10 24 Hz
AC 5:
Power 45 Watts Nominal
Sensitivity 88dB 1 Watt/ 1 Meter
Voice Coil 1 inch
Dcr 5.6 Ohms
Inductance .7 mH
Fs 69 Hz
Mmd 70
BL 4.6
Qms 1.784
Qes .722
Qts .514
Vas 7 liters
Recommended Crossover Zobel 23mfd cap with 7.5 Ohm resistor
Do these sound like they would be the right ones?
Thanks so much
Chris
cporada
« Reply #4 on: 12 Jul 2007, 09:35 pm »
:duh:
Sorry Mike,
My mistake; even if these are the right spec's, a frequency response plot would still be very handy once the dust has settled from ACI's move if that's possible
Thanks so much again
Chris
