PD-8Ci
0 Members and 1 Guest are viewing this topic. Read 3708 times.
ccappe
PD-8Ci
« on: 7 Jul 2007, 07:02 pm »
Are the PD-8Ci from bg corp still in production? Where can I buy those?
Danny Richie
Re: PD-8Ci
« Reply #1 on: 8 Jul 2007, 04:42 pm »
I am not sure if they were ever completely happy with their Neo 10 that is used in that design, so I don't really know if they ever made it available or not.
ccappe
Re: PD-8Ci
« Reply #2 on: 8 Jul 2007, 06:27 pm »
You may be right, but they still display it in their web site: http://www.bgcorp.com/productDetail.php?id=32
Are you sure the driver is a Neo 10 and not a neo 3?
Thanks for answering
Danny Richie
Re: PD-8Ci
« Reply #3 on: 8 Jul 2007, 07:10 pm »
My bad. I was looking at the picture to the left. It uses Neo 10's and Neo 3 pdr's. You were asking about their in ceiling speakers. You might try their dealer locator to see who might have some of those.
ewarren
Re: PD-8Ci
« Reply #4 on: 8 Jul 2007, 07:19 pm »
Those speakers are also marketed by sls loudspeakers.  If you can't find a BG dealer near you, check for a sls dealer.
