Jolida Music Envoy mono blocs - SOLD
Bill Baker
    • Musica Bella Audio
« on: 6 Jul 2007, 05:17 pm »
Hello folks, I have a pair of Jolida Envoy 200 watt 211 mono blocs here that were sent to me to sell on consignment. Upon arrival, I had one unit that is not getting B+ voltage (no bias).
 I do not have time to go inside of these nor do I have the means of testing 1000V+ circuits with my main Multimeter being down (the only one I have that can handle these kinds of voltages).
 What I can do for someone who purchases these is send them directly to Jolida to go over. Once they are in Jolida's hands, they would work with the buyer directly on the repair and shipping from their facility to you. My guess is that it is something simple (I have already tried different tubes) but do not know what the rate would be by Jolida to check them out.
Asking $1550 for the pair including shipping to Jolida Inc.
Suggested retail on these units is now: $8750 pr.
 These are older units and are the exact pair as reviewed at TNT Audio by one of our very own AC members: He purchased the review pair but ended up having to get rid of them when moving into a smaller home.
http://www.tnt-audio.com/ampli/musicenvoy_e.html
« Last Edit: 2 Aug 2007, 08:11 pm by Response Audio »
woodsyi
That's a tempting price and JoLida is right around here.   HHHMmmmmm. What to do.... :?
Nels Ferre
If anyone has any questions about these amps, feel free to ask here or PM me.
Bill Baker
Here are the specs on the Envoy amplifiers.
Here is a pic to get the general idea of what these amplifiers look like.
3000A 200 Watt Vacuum Tube Monobock Power Amplifier
Rated Output Power:  200 W per channel at 8 ohms, 25Hz to 40KHz
Frequency Response:  (at 1 watt into 8 ohms) 14Hz to 50KHz + 1dB
Distortion THD:  Less than 1% at 150 W output, 21Hz to 28KHz
Circuit Type:  Ultra Linear, Class AB
Input Impedance:  100Kohms
Input Sensitivity:  2.35mV at 1KHz and 8 ohms for 200 watt output
Output Impedance:  4 and 8 ohms
Tube Complement:  2 pcs. 211 power output; 2 pcs. El34 power drivers, 2 pcs. 12AT7 power drivers
Dimensions:  11 in. W X 19 in. D X 9 3/4 in. H
Power Requirements:  110V-120 VAC 60Hz 180 watts-standby, 850 watts maximum (220 VAC 50Hz option)
Weight:  60 pounds net each, approximately 65 pounds packaged  each
Bill Baker
Lots of inquiries but still available.
tdangelo
I had the JD3000's which are the same electrically but have more basic cases.  They were outstanding sounding.  I replaced 2 Butlers 2250's with these and really enjoyed them during the time I had them.  They do warm up the room quite a bit though...  I sold them because of the heat but now have a much bigger room where heat isn't an issue  :duh:  If you can get these fixed at a good price they are a steal ;)
Tony D.
Bill Baker
