Advice on adding a pre-amp to a Wadia 850
0 Members and 1 Guest are viewing this topic. Read 1310 times.
matix
« on: 1 Jul 2007, 03:57 am »
I am currently connecting my Wadia 850 direct to a pair of Acoustic Reality 1001 monoblocks.  I have previously sold off a CJ PV12 pre-amp as I find the direct connection no loss in Sound quality.  However,  I am trying to integrate my HT system into the 2 channel,  and thus again looking for a pre-amp with a HT bypass.  Any recommendation?  I am tired of switching out cables whenever I go from 2 channel to HT listening and vice versa.  But I am concerned of a pre-amp as it is adding another chain to the system.
Danny Richie
    • http://www.gr-research.com
Re: Advice on adding a pre-amp to a Wadia 850
« Reply #1 on: 1 Jul 2007, 06:07 pm »
The Dodd Audio battery powered tube pre-amp is easily one of the best ever made. It is reasonably priced and does have a home theater by-pass. Engaging the by-pass is pretty simple too. You just turn the pre-amp off and the input is connected to the home theater output.
http://www.doddaudio.biz/web/product_view.html?product=1
zybar
« Reply #2 on: 1 Jul 2007, 06:15 pm »
What about a high quality switch vs. a preamp?
It would be cheaper and has the potential to be sound better.
George
matix
« Reply #3 on: 2 Jul 2007, 09:18 am »
George
Hi George
I am afraid I am not aware of such a device.  Can give me some examples? Thanks!
mfsoa
« Reply #4 on: 2 Jul 2007, 03:25 pm »
Manley Skipjack
scottielee
« Reply #5 on: 3 Jul 2007, 06:22 pm »
maybe a high quality input selector such as this one from 47 Laboratory:
Bemopti123
« Reply #6 on: 3 Jul 2007, 06:35 pm »
I second this unit.  I have it and for all I can tell, it is transparent.  A little on the expensive side, but it well crafted and definitely up to par with the Wadia.
