Thanks Wayne.Pretty sick price for a cool toy.This would be much better than my Dell Axiom.Has anybody used Woot before? I have never heard of this site...George
I have many routers at the moment. But I am only using one at the moment. It is a wireless routers but also a wired router as most wireless routers have wired ports as well.
P.S. You can 'daisy chain' routers together, but I think the technical term is bridging them. M$ makes it pretty easy to bridge the routers, but they may not all play well together. Mine have always worked out. If you need a wireless router give me a PM. I have an older one that won't be SOTA but will work just fine for this purpose and is easy to use. Free if you pay the shipping.
Quote from: JoshK on 26 Jun 2007, 03:15 amP.S. You can 'daisy chain' routers together, but I think the technical term is bridging them. M$ makes it pretty easy to bridge the routers, but they may not all play well together. Mine have always worked out. If you need a wireless router give me a PM. I have an older one that won't be SOTA but will work just fine for this purpose and is easy to use. Free if you pay the shipping. Josh,Are you saying that I could buy a wireless router (technicall, wireless and wired) and daisy chain it to my wired-only router? That would be cool, as I really need around 6 wired connections, but most routers only have four. This would give me at least six to eight connections.
Actually, if you already have a wired router, all you need is a wireless switch - no need for a 2nd router.
Actually, if you already have a wired router, all you need is a wireless switch - no need for a 2nd router.Bryan
...so the wife and I go out for a chick flick and I get home just a little too late for the woot special, double whammy If anyone decides they don't want theirs drop me a line.
Quote from: bpape on 26 Jun 2007, 11:28 amActually, if you already have a wired router, all you need is a wireless switch - no need for a 2nd router.BryanThat's true. I have two (or three?) tiny little switches that have four ports on them. I think I'm only using one of them now, as I use them to add elements at the end of the run. In other words, I ran cable to one room, and if I need two devices in that room, I install the switch. However, I ran two network cables to each room so I'd probably be better off just hooking up the second cable.
That is a great deal. It's $150 cheaper than other places.
P.S. if anyone is looking for a killer router, I really like this one:http://www.newegg.com/Product/Product.aspx?Item=N82E16833127158It has everything, hi-speed wireless, gigabit router (gigabit cards are cheap now, so why not?). Its not quite as easy to setup as my previous no-brainer wireless, but not difficult either and it is rock solid. Its fast, reliable and I get good signal throughout my house with my laptop which I didn't before. No complaints.
