Almarro A205A Mk.II and VH Teflon V-Cap upgrade
dspringham
« on: 23 Jun 2007, 02:03 am »
Just purchased an Almarro A205A Mk.II and have heard much about replacing the stock coupling caps with Teflon V-Caps to improve sonics.
The question is - should the stock caps be replaced with V-caps of the same value or some other value. I've heard that changing the value alters the low end response.
Comments greatly appreciated.
David
Bill Baker
    • Musica Bella Audio
Re: Almarro A205A Mk.II and VH Teflon V-Cap upgrade
« Reply #1 on: 23 Jun 2007, 02:19 am »
Hello david,
 This would greatly depend on what speakers you are using. ere is what I have always based this one;
1) If you are running smaller, full range drivers such as Omega speakers with the 5" or 6" driver and NOT using a sub, I would increase the size of the cap a bit.
2) If you are using speakers that already have a decent amount of extension down below or using a smaller speaker as mentioned above but also using a subwoofer, you can stick with the size that's currently in the amp. This will allow the amp to concentrate on the ciritical midrange more precisely.
 I have always found that the best overall cap for the 205 MKII is the .068uF (it should have a .047uF in there now). This size seems to work best with a good majority of speakers.
dspringham
« Reply #2 on: 23 Jun 2007, 02:34 am »
Thanks for the rapid response Bill (guess that's why you're called Response Audio!).
I will probably run the amp with Cain & Cain Abbys (I've read/heard that there is great synergy with this combo) along with a subwoofer (Gallo  Acoustics TR-1).
From what I understand then, I could probably go with the same value for the V-cap replacement as the stock value (.047 uF) or do you think that the C & C Abbys with sub would be best served with the .068 uF value.
Thanks again Bill
Bill Baker
« Reply #3 on: 23 Jun 2007, 02:50 am »
Sure, you could do well with either value. The larger value will provide you with a *bit* more fullness / body in the midrange as the 205 is a very precise sounding amplifier. The price difference is small between the two. The choice is yours of course depending on your personal preferences..
 I have also custom built/modified quite a few 2A3 & 300B SET amps for Cain & Cain owners and increasing the size of the coupling capacitors was requested on all of them so far.
 Here is one of the more recent amps I did for a customer that had the Abbys. It a highly modified and customized ASL 2A3 Tulip (3.2 watts).
dspringham
« Reply #4 on: 23 Jun 2007, 02:58 am »
I'll probably go with the .068 then.
Thanks again Bill for the great and timely information.
David
