Best version Something Else CD/Xrcd/SACD
carusoracer
« on: 19 Jun 2007, 01:14 pm »
Looking for best version "Something Else" CD/Xrcd/SACD
Great remasters or certain Blue Note CD vintage.
I really think that Cannonball Adderly and Company were at their finest in the recording 8)
ted_b
Re: Best version Something Else CD/Xrcd/SACD
« Reply #1 on: 19 Jun 2007, 01:22 pm »
Mark,
To me, hands down, it is the 24/192 HDAD (high rez DVD-Audio disc; with 24/96 pcm on flip side, playable on any DVD-video player capable of 24/96).
http://store.acousticsounds.com/browse_detail.cfm?Title_ID=14910
« Last Edit: 19 Jun 2007, 01:33 pm by ted_b »
carusoracer
« Reply #2 on: 19 Jun 2007, 04:15 pm »
Thanks for the replies...I do not have a DVD A capable player in my system :|
Any other versions or can either you make a disc of your version?
ted_b
« Reply #3 on: 19 Jun 2007, 04:31 pm »
Mark,
You don't have a decent DVD player?  That's specifically why I mentioned that the HDAD has a simple pcm version on side 2, with tremendous 24/96 sonics (only a detailed a/b would likely point out the superior sonics of the 24/192 side).  I still think the 24/96 pcm is better than the redbook or xrcd options .
Edit:: Didn't see Tvad4's same retort.......thinking like genuises  :D
carusoracer
« Reply #4 on: 20 Jun 2007, 03:01 pm »
I have two DVD players but my system is two channel. I'm looking for a good version that is compatible on my CDP SACD/CDR/Redbook format.
ted_b
« Reply #5 on: 20 Jun 2007, 03:08 pm »
Ah, I see.  Well, although the HDAD is also only two channel, you'd have to integrate the DVD player into the system.  I don't know of the quality of the other options.  It may be worth trying one of your DVD players; I'd send the disc down with Jennifer or mail it to you for a demo if needed.  It's REALLY good.
Ted
